Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
08-12-2010, 22:51 | #77101 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9419 Status: Offline Thanks Meter: 1,030 | Quote:
Unlock: 63648672 Network unlock code (NCK): 1. Remove the SIM card and connect the USB Modem to the PC 2. Run the HUAWEI_MODEM_Code_Write 3. click - Please Select Com Port 4. click detect and slect your modem from list then click accept 5. click Unlock Modem and enter your 8 digit unlock code 6. click ok Link1: HUAWEI_MODEM_Code_Write Link2: HUAWEI_MODEM_Code_Write Link3: HUAWEI_MODEM_Code_Write or 1. Install Mobile_Partner_11.030.01.07.03 2. Insert your NEW provider's sim card into the modem and plug modem into your computer / laptop. 3. The MOBILE PARTNER will ask for an unlock code - type your 8 digit unlock code Mobile_Partner_11.030.01.07.03 Mobile_Partner_11.302.09.01.539_Voice_USSD AT-command: AT^CARDLOCK="your 8 digit unlock code" Firmware flash code (Flash): 1. Double click the .exe (Flash) 2. Enter your 8 digit flash code Flash your old branded firmware to the latest generic from huawei. K3765_Update_11.130.03.00.00.B418 K3765_dashboard_UTPS11.002.03.32.100_MAC11.110.02. 22.100.B416 You do at your own risk! Best regards, Edward1 | |
The Following User Says Thank You to Edward1 For This Useful Post: |
08-13-2010, 00:11 | #77103 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1198281 Status: Offline Thanks Meter: 28 | Attach modem to computer then restart the computer.. Hint : Always use the same USB outlet for the modem If that doesnot work then uninstall the software for the modem via control panel : restart computer > attach modem and let it install the dashboard, you may need to remove the modem and replace it for the process to finish.. Be patient as it can take up to 10 mins to install..more info of Opp system would be handy ... |
08-13-2010, 07:15 | #77115 (permalink) |
Member: 9419 Status: Offline Thanks Meter: 1,030 | Supported models: Huawei: E122, E156, E156C, E155, E155X, E156G, E160, E160E, E160G, E161, E166, E166G, E169, E169G, E170, E170G, E172, E172G, E176, E180, E180S, E180G, E181, E182, E182E E196, E216, E219, E226, E230, E270, E271, E272, E510, E612, E618, E620, E630, E660, E800, E870, E880, E1550, E1551, E1552, E1553, E1609, E1612, E1615, E1616, E1630, E1632, E1690, E1692, E1750, E1750C, E1752, E1756, E1762, E1803, E1820, K3517, K3520, K3710, EG162, EG162G, EG602, EG602G, UMG181, UMG1691, UMG1831, EM770, S4011 E585, E5830, E5832, E5838 http://forum.gsmhosting.com/vbb/f88/...k-here-982617/ Vodafone: K2540, K3250, K3512, K3515, K3520, K3565, K3715, E3735 ************************************************** ************** Unlock SIM Lock status : Locked (customized firmware) dc-unlocker_client-1.00.0509.exe 1. Install DC-Unlocker client 2. Run the DC-Unlocker client SIM Lock status : Locked (customized firmware) 3. Double click the firmware.exe 4. Enter your 8 digit flash code 5. Run the DC-Unlocker client SIM Lock status : Locked (Card Lock) 6. Run the HUAWEI_MODEM_Code_Write 7. click - Please Select Com Port 8. click detect and slect your modem from list then click accept 9. click Unlock Modem and enter your 8 digit unlock code 10. click ok You do at your own risk! ************************************************** ************** |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f88/huawei-unlocking-codes-request-only-here-781410/ | ||||
Posted By | For | Type | Date | |
Unlock Idea net setter Eg162G | This thread | Trackback: | 04-20-2011 20:54 |
ZTE MDM Unlocking codes Request [ONLY HERE] | DanilowAlexandr | Phone Unlocking Codes & Maps | 11 | 03-19-2010 18:48 |
Huawei MDM Unlocking codes Request [ONLY HERE] | samalik | Infinity-Box | 5 | 02-10-2010 16:23 |
