Nokia 3650 by T-Mobile Impossible?! I just read somewhere on the forum that it is impossible to unlock a Nokia 3650 by T-MobileUSA with a code.... Is this true?! Or can it be done? If using a calculator what settings would you need (asic2,asic5? and v1,v2, or griffin codes)?? |
itīs possible!!! but you need providercode!!! T-Mobile USA has 13 different codes! you can read your providercode with cable and bWinLock. settings are: dongle V2 type 5 correct Imei correct providercode |
I think I read somewhere and have seen at another forum that users are getting their 3650 T-Mobile unlocked by using ONLY provider code: 31020 and by using the first lock code and then the 7th(last) as a backup. I have a 3650 T-mobile coming in the next day or so and I was nervous about this but I will give this provider code a try and if it fails I might need some help from the good friends here at GSM-Forum. Thanks! |
Let me know the IMEI and I will give you the code..... It is easy.... You just need to know the right code...... |
i need one too.. tmobile USA imei: 351102501078579 model: nokia 3650 thanx in advanced! |
Imei: 351102501078579 ----------------------------------- Type: 5 ----------------------------------- Operator: 31020000, U.S.A., T-Mobile 3650 ----------------------------------- ----------------------------------- #pw+325836051330232+1# #pw+236915066471116+2# #pw+403307037135001+3# #pw+438527767627224+4# #pw+428447257676240+5# #pw+799210726734411+6# #pw+904832531260234+7# |
