01-21-2017, 15:30
#1 (permalink)
Member: 79315
Thanks Meter: 6,024 | Using iBUS Data Cable S1 Flash iWatch S1 (World First Solution) By MFC Dongle Using iBUS Data Cable S1 Flash iWatch S1 (World First Solution) By MFC Dongle What is iBUS Data Cable S1 ? - Working With MFC Dongle V2.0 or New
If your Apple Watch displays a red exclamation point after a software update, No more need to contact Apple Support for service. After iWatch Glass Digitizer Replaced No more headache, After iWatch software problem no more pain. So this is the feature: - Full Support iWatch S1 38mm & 42mm
- Support iWatch S1 restore and repair software
- Support Downgrade and upgrade firmware
- Support iWatch touch programming etc
[info] Starting ...
[info] Using LOCAL IPSW C:\MFC\iDeviceTools\watch1,1_2.1_13s661_restore.ip sw
[info] using cached version data
[info] Found device in Normal mode
[info] Database recognized as:
Generation: Apple Watch
'A' Number A1553
Bootrom
Variant Watch1,1
FCC ID BCG?E2870
Internal Name 27aAP
Identifier Watch1,1
Color Silver
Size 38 mm
Model MJ2T2
[data] ModelNumber:MJ2T2
[info] Extracting BuildManifest from IPSW
[data] Product Version: 2.1
[data] Product Build: 13S661 Major: 13
[data] Device supports Image4: true
[info] Variant: Customer Upgrade Install (IPSW)
[info] This restore will update your device without losing data.
[info] Found ECID 3797257798132
[info] Getting ApNonce in normal mode...
[data] E6733DF56B5813A60A1658B35B1599B7A548F27E
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in normal mode...
[erro] Unable to get SEPNonce from lockdownd
[info] failed
[warn] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[info] NOTE: Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[warn] Unable to find BbSkeyId node
[info] Sending TSS request...
[erro] Unable to find required ApSepNonce in parameters
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/watch1,1_2.1_13s661_restore/058-26545-063.dmg'
[info] Entering recovery mode...
[info] Apple device disconnected!
[data] UniqueChipID:506708468
[data] ModelNumber:Apple Watch
[data] ProductType:Watch1,1
[info] device serial number is FH7PWNxxxxxxx
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n27a.RELEASE.im4p...
[info] Sending iBEC (602407 bytes)...
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-2817.20.25
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@115~watch.s7002.im4p...
[info] Sending AppleLogo (6565 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 058-26519-063.dmg...
[info] Sending RestoreRamDisk (24154331 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n27aap.im4p...
[info] Sending RestoreDeviceTree (77188 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.n27a...
[info] Sending RestoreKernelCache (8866162 bytes)...
[info] Restoring device...
[info] Waiting for device...
[info] Apple device arrival ... searching USBMux for device after 100ms
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 13
[info] Device a71459c2a943535665af51b4c2a7139e2ee51c36 has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 2
[info] ChipID: 28674
[info] UniqueChipID: 3797257798132
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49156)
[info] Sending RootTicket...
[done] sending RootTicket
[info] Waiting for NAND (28)
[warn] FDR 09F8D7C0 got sync message
[info] Connecting to FDR client at port 49156
[warn] FDR 0A4529E8 got plist message
[info] Unmounting filesystems (29)
[info] Mounting filesystems (16)
[info] Updating IR MCU firmware (51)
[info] Sending filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[done] sending filesystem
[info] Verifying restore (14)
[info] Sending KernelCache...
[done] sending KernelCache
[info] Installing kernelcache (27)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash/all_flash.n27aap.production
[info] Getting firmware manifest Firmware/all_flash/all_flash.n27aap.production/manifest
[info] Extracting LLB.n27a.RELEASE.im4p...
[info] Extracting iBoot.n27a.RELEASE.im4p...
[info] Extracting recoverymode@115~watch.s7002.im4p...
[info] Extracting dali-ui.n27a.release.im4p...
[done] sending NORData
[info] Flashing firmware (18)
[info] Clearing NVRAM (46)
[info] Fixing up /var (17)
[info] Modifying persistent boot-args (25)
[info] Restore Finished
[info] Cleaning up...
[done] Done
