Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 06-03-2015, 06:26   #1 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,556
Post BST Dongle - BST uart cable connection communication failed!
Try to solve problem as follow way if you facing uart cables connect communication failed problem:
First of all, confirm you BST uart cables connect way is correct:
Phone > BST uart cables (R150K, R523K, R619K) > BST PCB Adpater (or other univeral interface box) > USB A-B Cable > PC USB Port.
1. Check Phone Baseband Version (type *#1234# check cp value is blank or not, if cp value is blank thats mean phone baseband unknown), if phone baseband unknown try solve baseband unknown problem 1st.
Try solve phone baseband unknown problem as follow way:
1). Flashing with correct fullflash
2). Write Default EFS (or Wipe EFS) -- suggest backup original efs before write default efs or wipe efs
3). Reboot phone check baseband version again.
2. Check PL2303 Driver Version (run bst software check pl2303 driver version & release date on logs window, if you can see "OK" with green color thats mean you pl2303 driver working sure, otherwise re-install bst pl2303 driver, X:\BST\Drivers\PL2303_Prolific_DriverInstaller_v1. 8.0.exe)
3. Keep the phone connected uart cables and then reboot phone.
4. Keep phone screen on and then try uart cable communication (Press "Home" button)
P/S:
1). How to solve Old BST Pcb adapter android 4.4.x not working
2). How to Enable uart communication via disable battery BSI
The Following 16 Users Say Thank You to EmeGSM-Wei For This Useful Post:
Old 06-03-2015, 06:26   #2 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,556
[Kept by GsmBest Team]
The Following 2 Users Say Thank You to EmeGSM-Wei For This Useful Post:
Old 06-03-2015, 13:44   #3 (permalink)
Member: 902518
in galaxy s6 how to disable battery for conexion uart ??
Old 06-04-2015, 00:36   #4 (permalink)
Flux Capacitor's Avatar
Member: 1430518
Thanks Meter: 25
or is there another procedure for this model?
Old 06-04-2015, 10:31   #5 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,556
Hi, Flux Capacitor
Galaxy S6 uart communication without battery BSI Off, next updates we will show which model need tape battery BSI on Help window.
Best Regards
GsmBest Team
The Following 3 Users Say Thank You to EmeGSM-Wei For This Useful Post:
Old 06-04-2015, 13:24   #6 (permalink)
Member: 902518
galaxy s6 is with internal battery !!!
Old 06-04-2015, 18:37   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,346
Note4, S5 that not want Wipe, S6 and all other New device that not want do Wipe Security/Efs must need of:
Block battery's proper contact by using a tape, connect the phone to BST, when request, with Micro UART 530K resistor cable and write the IMEI Certificate, after Wiped EFS, here photo:
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 06-19-2015, 09:37   #8 (permalink)
Member: 2061249
Thanks Meter: 18
allumts
lol well the s6 cannot block that because it doesn't have removable battery
Old 06-19-2015, 10:31   #9 (permalink)
allumts's Avatar
Member: 1564612
Hey...LOL are you and respect other members...if for MY MISTAKE have wrote also S6 isn't Dead anybody....who have S6 in his handle know good that cannot remove battery...
Anyway, no need Cip ciop with you for these thinghs.... SORRY TO ALL USER, my mistake in writing also S&, but for Other New Device Note4, S5 series is Valid this small Tip.
allumts
Old 07-03-2015, 23:48   #10 (permalink)
Member: 2190671
I was able to make it work on the s6 by going to *#0*# menu but after the imei is written succesfully there is no signal, and the repair network option is not available
Old 07-05-2015, 16:07   #11 (permalink)
Member: 527921
Thanks Meter: 23
S6 Battery Covered
Does the Samsung SM-G920T battery need to be covered like the S5 and Note 4 for the UART Cable to recognize it?
If so this will be an issue for many...
Old 07-14-2015, 18:08   #12 (permalink)
Member: 1815910
Thanks Meter: 8
Samsung Note 3 neo(N750) imei null problem....
Please Explain:-
1)Which URAT cable use this model?
2)Block battery's Conecter use tape Yes or no?
2)how to Repair Imei number best tool?
Old 07-14-2015, 18:46   #13 (permalink)
allumts's Avatar
Member: 1564612
NO, in S6 no need cover BSI...and in S6 battery cannot take out... only Update GOOD how all others can work in this model.
allumts
Old 07-17-2015, 00:16   #14 (permalink)
Member: 2429367
Thanks Meter: 7
S6 UART Not Connecting
What is solution to fix this problem
Old 07-21-2015, 14:51   #15 (permalink)
Member: 1815910
Thanks Meter: 8
iam buy New Bst Dongle today....
But 523k Urat not working Samsung note 3 neo N750 imei Repair Option?
Help urgent......
The Following 5 Users Say Thank You to jaiprakashsmt For This Useful Post:
Page generated in 0.21909 seconds with 8 queries
