Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 03-10-2016, 15:04   #46 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,346
Originally Posted by Muazzam786 View Post
If your phone fails to connect via uart cable try this method
1 Dial *#0808# and select last option adb+modem+db
2 now disable battery bsi point
3 if still not dial*#*0# and connect cable
No need to done anything on samsung s6 and s6 edge
Regards it will work 10000%%%%
Not because its method ,Because Bst is Mother of All samsung invention Big Bow
Other Misguiding other users.
What disable battery "BSI" point Lol...it's was one Tip ONLY for Some S5 and sometimes for Note 4, but is just solved.
Want help and not have enough knowledge for help others, first help yourself with Knowledge in this field...have one dongle in the handle and think of to know all Tips and Tricks...incredible.
For this enter in my shop 50% of phone damaged from New user of the Box/dongle...
Old 03-12-2016, 22:55   #47 (permalink)
Member: 2292877
Thanks Meter: 4
tape
u need TO PUT TAPE on the battery. the middle pin between positive and negative. then it will connect
The Following User Says Thank You to alex88morris For This Useful Post:
Old 03-12-2016, 23:10   #48 (permalink)
allumts's Avatar
Member: 1564612
Last time that Misguide other user.
Next same post will be deleted for Spam and MISGUIDE users.
Have explained clear above, ANY TAPE !!!!
allumts
Old 04-14-2016, 21:09   #49 (permalink)
Member: 1202938
iam buy New Bst Dongle today....
But 523k Urat not working Samsung note 3 neo N750 imei Repair Option?
Help urgent......
just take off bettery 3 no pin with costep
Old 04-14-2016, 21:11   #50 (permalink)
Member: 1202938
plez help,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,how to repair imei sm-a500h with uart cable.....bcoz bettery is fixd
Old 04-16-2016, 14:55   #51 (permalink)
Member: 2321828
Thanks Meter: 7
bhai iss problem ka kya solution hai.... mere sath bhi yahi problem ho rahi hai.............
samsung j500f \main
Old 05-12-2016, 09:10   #52 (permalink)
MobileCarein's Avatar
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
note 3 neo
Can't connect to device, please check the cable connection communication failed.......Please help me !!
Old 10-01-2016, 04:28   #53 (permalink)
Member: 2167021
Originally Posted by ramosrdv18 View Post
I was able to make it work on the s6 by going to *#0*# menu but after the imei is written succesfully there is no signal, and the repair network option is not available
thank you bro. this method solved my problem
Old 11-05-2016, 01:55   #54 (permalink)
Member: 2555136
Thanks Meter: 31
any help havi this problem now
Checking DRK ... PHN-P:20141017:01:00:00403085:ROOT
Repairing DRK ...
Checking DRK ... PHN-P:20140914:01:20:00527807:ROOT
Connect to device ...
Device Authentication ... failed with MSL
Verify Phone Cert ... Failed
Device Info (UART) ... failed
Time used : 8.3 s
Time used : 8.7 s
Scanning devices ... 0 found
Device Info (UART)
Model: SM-N910L
SW Version: N910LKLU2CPB1
Customer Code: LUC
Unique Number: CR2007575F21681
Flash Memory: -
Chipset : true
Key ID : 0760
Time used : 1.4 s
The Following User Says Thank You to Maycol1984 For This Useful Post:
Old 12-17-2016, 16:01   #55 (permalink)
Member: 281992
Sonork: 100005
Thanks Meter: 4
s6 uart
hello
how to conect S6 via uart?
step by step plz
Old 01-09-2017, 10:13   #56 (permalink)
Member: 2473266
Thanks Meter: 4
Bro need Help Communication Port Not detecting Any thing.
Old 01-24-2017, 07:40   #57 (permalink)
Member: 2644717
Uart failed
Please help.
uart failed,i have set usb to dm+modem+adm,but stil not conect..
Old 02-03-2017, 04:54   #58 (permalink)
Member: 2627156
uart connection ok thanks
Old 02-03-2017, 13:09   #59 (permalink)
Member: 1649119
Thanks Meter: 3
its my problem to and ive search a lot but i cant find a soloution
Old 02-03-2017, 13:31   #60 (permalink)
allumts's Avatar
Member: 1564612
For enable UART: when Sw prompt of connect Uart cable, Screen need of to be ON, (set to 5 min.s), digit this code: *#0*# and connect Uart cable
Post result
allumts
The Following 3 Users Say Thank You to allumts For This Useful Post:
Page generated in 0.18857 seconds with 8 queries
