BST / BSTPro Dongle BestSmartTools Official Support Section |
04-02-2014, 08:25 | #1 (permalink) |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,496 | BST - SM-N9005 IMEI Repair without 2G network problem (support 4.3 & 4.4.2) How to IMEI Repair SM-N9005 via BST: 1. Root your phone with CF-Root files. 2. Go Samsung > Service > Repair, Do "Write Default EFS" 3. Repair 3G network 4. Go Samsung > Flashing tab, click "Help" and then setting phone as tips. 5. Write SuperIMEI (Connect 523K uart cable when software request) 6. All done, reboot phone. Best Regards GsmBest Team Last edited by EmeGSM-Wei; 04-10-2014 at 16:43. |
The Following 14 Users Say Thank You to EmeGSM-Wei For This Useful Post: |
04-06-2014, 13:00 | #9 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1489224 Status: Offline Thanks Meter: 7 | Hello friends, I have a question, I did all the steps to repair imei and 3g using the Super imei me works only with default, when you write the original imei everything perfect but says not registered on the network, is there a way or procedure to work with if the original imei?? thank you very much for your help |
04-06-2014, 15:10 | #10 (permalink) |
Freak Poster Join Date: Feb 2011 Location: nowhere
Member: 1511582 Status: Offline Thanks Meter: 74 | not right now the fix its with clear the efs 000000out everthing then use the super imei that's all you can do for now everthing should work with super imei |
