Can not change imeid/network unlock sm-g900r$ Just cant network unlock SM-G900R4. IT says unlock ok and all lock written "00000000" but not network unlock.. Baseband is fixed and it can replace IMEI number as per BST default (by checking in my phone:settings->about->status->imei) but not the MEID/ESN... so when I press to check the iMEID by *#06# it shows B0000000. I can't do repair network because the button is disabled. Thank you I use this procedure: How to unlock SM-G900R4: 1. backup efs & nvm; 2. write default efs 3. write superIMEI 4. put sim card check network, do "repair network" if no have network Best Regards GsmBest Team |
evice Authentication ... Unlocking device ... ok All lock written to '00000000' Reboot device to NORMAL mode ... Re-scan device before any operation please Time used : 2.9 s Device Authentication ... Master Lock: Encrypted Network Lock: Encrypted Sub Lock: Encrypted SP Lock: Encrypted CP Lock: Encrypted SIM Lock: Encrypted If not support read codes, use Unlock instead Time used : 28.7 s |
Same for me!, im thinking on make an issue refund. |
