BST / BSTPro Dongle BestSmartTools Official Support Section |
07-20-2015, 10:37 | #34 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Quote:
this new security wait for updatre* 5.1.1* | |
07-21-2015, 06:51 | #35 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 527921 Status: Offline Thanks Meter: 23 | No Connection after Recent update Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G920T Hardware: SAMSUNGEXYNOS7420 Mode: normal Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds |
The Following User Says Thank You to enigmadapuzzle For This Useful Post: |
07-23-2015, 17:32 | #36 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Pescara, Italy
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | Man... i do everything you said.... got a sm-g925f with 5.0.2. android i've rooted with cf-root... wipe efs... write default efs... i brought on internet the 523k cable that you said.... but...always same trouble... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds is there any particular software needed to flash to do imei write? or any setting to set? |
The Following User Says Thank You to ceatele For This Useful Post: |
08-21-2015, 08:16 | #39 (permalink) |
Freak Poster Join Date: Aug 2002 Location: Latino_ America Age: 51
Member: 14862 Status: Offline Thanks Meter: 40 | failed write cert !! no work for me to write the certificate g925i. the cable uart, works well with the model g900m. ( i tried the cable uart into another phone and it work well) |
08-21-2015, 18:20 | #40 (permalink) | |
Member: 14862 Status: Offline Thanks Meter: 40 | repair imei g925i .ok ! Quote:
2.-write cert 3.- write efs (if id donīt get betwork signal then write the backup efs | |
The Following User Says Thank You to jose miguel For This Useful Post: |
09-20-2015, 16:28 | #44 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1489224 Status: Offline Thanks Meter: 7 | Excellent BST. and Mr. Gsm. 100% working all signal and data coverage. G920F in S6 .. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G920F Hardware: SAMSUNGEXYNOS7420 Mode: normal Checking environment ... System Info Display ID: LRX22G System Ver: 5.0.2 REL API Level: 21 Incremental: G920FXXU1AODG Model: SM-G920F Brand: samsung Device: zeroflte Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 04157df4cb25b204 Hardware: samsungexynos7420 Model: zeroflte PDA Version: G920FXXU1AODG Phone Version: G920FXXU1AODC Bootloader ver: G920FXXU1AODG Ril Hw Version: MP 0.80V Sales Code: VOD Model ID: UNKNOWN Get Bluetooth info failed WiFi MAC: e8:50:8b:e3:17:a9 WiFi interface: WiFi state: COMPLETED Root Access: ROOTED Tiempo de Uso : 3.4 s Prepare environment ... Backup EFS ... C:\BST\backup\samsung\efs\SM-G920F\EFS_samsung_SM-G920F__2015-09-20_14.01.26.efs ok Wiping EFS ... ok Tiempo de Uso : 19.4 s Reboot device to DESCARGA mode ... Wait device ready ... Connect to device ... Reparar EFS ... Flash completed Tiempo de Uso : 3.1 s Connect to device ... Device Authentication ... Escribiendo IMEI ... Writing IMEI certificate ... ok, You need reboot device |
The Following User Says Thank You to ffalcetta For This Useful Post: |
10-17-2015, 13:58 | #45 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | SerialNumber: 05157df5242e2704 Hardware: samsungexynos7420 Model: zerolte PDA Version: G925FXXU1AOCV Phone Version: G925FXXU1AOCW Bootloader ver: G925FXXU1AOCV Ril HW ID: Sales Code: O2U Model ID: UNKNOWN Get Bluetooth info failed Get WI-FI info failed Root Access: ROOTED Time used : 3.5 s Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds |
The Following User Says Thank You to skyulock For This Useful Post: |
