Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 10-24-2016, 05:34   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
How to remove Mi account on Mi5? [ANSWERED]
1 im enter phone to fast boot and click on Scan button
2 im click Reset account
3 phone restart to EDL mode but phone power on normal with locked Mi acc
would u pls help me all user and supporter
The Following User Says Thank You to 089999945 For This Useful Post:
Old 10-25-2016, 09:31   #2 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
oh no answer,so not suported? if not give back to user
Old 10-25-2016, 15:48   #3 (permalink)
Member: 1968946
Thanks Meter: 99
No answer, no update, this is the end of BST!!!!!!
Old 10-27-2016, 12:24   #4 (permalink)
Member: 2641745
i am also facing same problem but no support or reply yet.
Old 10-27-2016, 12:55   #5 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
if not support say not is good,but all time all device not support,
supporter BST alway skip
Old 10-27-2016, 13:12   #6 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
use fastboot rom ver 7...
patch account lock relock with bst
flash the patched firmware with miflash via edl
DONE
Old 10-27-2016, 14:53   #7 (permalink)
Member: 216844
Thanks Meter: 30
Scanning devices ... 1 found
dev[1] e73aa39e
Mode: fastboot
Hardware: MSM8996
Manufactory: UNKNOWN
MID:
Start unlock ... Need reboot device to normal
Removing Account Lock ...
Boot to EDL mode ... done
Wait device ready ...
Connect to Sahara (COM10) ...
Sending Loader ...
Connect to Firehose ...
Writing data ... ok
EDL mode operation done , hold (20s) phone power button to restart
With xiami deep flash cable but no remuve mi account
Old 10-27-2016, 17:31   #8 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
DONE
Old 10-27-2016, 17:45   #9 (permalink)
Member: 216844
Thanks Meter: 30
my butlooader is locked. Is posible flash patch firmware
Old 10-27-2016, 19:03   #10 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
use edl mode flash via miflash, no matter lock or unlock
Old 10-27-2016, 19:22   #11 (permalink)
Member: 216844
Thanks Meter: 30
Only flashed with miui7 mi accaunt remuvd no need patch
Old 10-27-2016, 19:56   #12 (permalink)
Member: 216844
Thanks Meter: 30
after 5-6min mi accaount locked my phone
please link to downloads patch firmware
Old 10-28-2016, 01:59   #13 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,610
Hi, 089999945
Phone auto reboot on normal mode thats mean cannot boot into EDL mode via fastboot mode. solve problem as follow way:
1. Enter EDL mode via xiaomi deep flash cable (install drivers if needed)
2. Press "Reset Account Lock"
3. Do "Patch Account Lock Relock" via BST and then flash it via MiFlash please.
4. Power on without network connect (remove sim card and wifi), after power on then connect network.
You can check video here:
Remove Account lock via Disable Account lock Relock: http://www.gsmbest.com/en/ShowSupport.Asp?Id=175
Remove Account lock via Patch Account lock Relock: http://www.gsmbest.com/en/ShowSupport.Asp?Id=174
Remove Account lock via Patch Account lock Relock: http://www.gsmbest.com/en/ShowSupport.Asp?Id=181
Best Regards
GsmBest Team
The Following 2 Users Say Thank You to EmeGSM-Wei For This Useful Post:
Old 10-28-2016, 02:04   #14 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,610
Hi, Selmir
Use "Patch Account Lock Relock" or "Disable Account Lock Relock" function to solve this problem.
* About Xiaomi "Disable Account Lock Relock" tips:
1). Reset Account Lock
2). Power on the phone and turn off network immediately (suggest remove SIM card and turn off WIFI)
3). Enable "USB Debugging" (Settings > About phone > Tap "MIUI version" continuously to enable developer mode > back > Additional settings > Developer options > turn on "USB debugging")
4). Press "Disable Account Lock Relock" button waiting operation done, turn on network
* About Xiaomi "Patch Account Lock Relock" tips:
2). Press "Patch Account Lock Relock" button and then select stock rom for current phone (select "images" folder)
3). After rom patch done, will auto create "images_patched" folder on the root directory
4). Flash patched rom via MiFlash tool(download tool from bst support site or xiaomi offical website)
5). Turn off network when power on wizard (SIM and WIFI), Turn on network after phone power on
p/s: you can patch xiaomi roms via "Patch Account Lock Relock" button directly.
Best Regards
GsmBest Team
Old 10-28-2016, 08:08   #15 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by GsmBest-Wei View Post
Hi, 089999945
Remove Account lock via Disable Account lock Relock: BST-Xiaomi 5(2015628) Reset Account Lock/Cloud Lock - Support - GsmBest Team
Remove Account lock via Patch Account lock Relock: BST-Xiaomi Redmi 3S(2016030) Reset Account Lock/Cloud Lock - Support - GsmBest Team
Remove Account lock via Patch Account lock Relock: BST-Xiaomi Mi5SPlus(2016070) Reset Account Lock/Cloud Lock - Support - GsmBest Team
Best Regards
GsmBest Team
good,but i give back to user ready.
Page generated in 0.19599 seconds with 8 queries
