Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 10-22-2016, 12:31   #1 (permalink)
Member: 585584
Thanks Meter: 4
BST reset FRP samsung j320G
How to reset google account j320G
Old 12-18-2016, 14:51   #2 (permalink)
Member: 468632
Thanks Meter: 60
Yeah me too friend,hopefully BST team will update the tool
Old 12-18-2016, 14:55   #3 (permalink)
Member: 468632
Thanks Meter: 60
lucky me bro,i try with octopus ,its working like charm.you should try with octopus bro......!
Welcome to Octoplus/Octopus Box Samsung software version 2.4.6
To connect SCL24 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Restart phone.
11. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: SM-J320W8
Searching for a phone. Please wait...
Can't kill external ADB references. Please, close all programs that use
ADB server.
Phone was not found on the selected port!
Searching for USB diagnostic port...
No diagnostic ports found!
Connecting to phone on COM25
Phone connection failed
Performed by 2.4.6 Software version.
Selected port: COM1
Searching for a phone (waiting for ADB device)...
ADB server.
Operation was canceled
Selected port: COM1
ADB server.timeout
Phone not found.
Operation was failed!
To connect SM-J320G phone you have to perform the following steps:
Selected port: COM1
Selected model: SM-J320G
Reading info, please wait...
ADB server.
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Selected port: COM1
ADB server.
Selected interface: USB
Searching for device. Please wait...
Waiting for device...
Found device on COM22
Reading info...
Detected device model: SM-J320G
HW Version: SM-J320GZWDXID
PDA version: J320GXXU0APD3
CSC version: J320GOLE0APD3
CP version: J320GXXU0APD2
Device SN: RR8H60AQDEX
Device IMEI: 356412-07-273422-8
FRP/Reactivation: TRIGGERED
Operation was cancelled!
Selected interface: UART
Note: Type *#0*# on the phone and connect UART cable.
Device not found!
Selected port: COM1
ADB server.
Selected port: COM1
Reset FRP/ Reactivation lock operation for SM-J320G will delete all user
data on the phone (contacts, pictures and others)!
NOTE: You can reset FRP/ Reactivation without losing user data via
Factory Reset FRP/ Reactivation service.
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Resource files already downloaded.
Please put the phone into Download Mode and connect USB cable.
To put SM-J320G into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Waiting for phone...
Firmware write started.
Writing Custom section...
Custom section has been written successfully.
FRP lock is successfully reseted!
Wait 3-4 min then goto "Backup and reset" and make "Factory data
reset"
Page generated in 0.13662 seconds with 8 queries
