BST / BSTPro Dongle BestSmartTools Official Support Section |
12-17-2016, 12:58 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Palermo
Member: 281998 Status: Offline Thanks Meter: 117 | [World 1st] Samsung SM-G360F Imei Write Done ( Super Imei) By <<BST Dongle>> Here Im Shareing To 1more World 1st Solution For All BST Users Only My problem is IMEI: /01 1-Root Device: https://download.chainfire.eu/762/CF-Root/CF-Auto-Root/CF-Auto-Root-coreprimelte-coreprimeltexx-smg360f.zip 2-Wiping EFS 3-Bypass MSL 4-Block battery’s proper contact 5-Disconnect USB Cable and Connect device with micro uART 530K resistor cable 6-Write (Super_ IMEI )… 7-Repair network … IMEI Repair Done Code: Fw.Ver : BstKey V3.33 Serial : 3C7F-XXXX-XXXX-XXXX Active User: Salwos-GSM PL2303 : 3.8.3.0 2016-10-06 Best Smart Tools, Load OK. ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G360F Hardware: QCOM Mode: normal Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G360F Hardware: QCOM Mode: normal Saving backup file to "C:\Program Files (x86)\BST\backup\samsung\nvm\SM-G360F\NVM_samsung_SM-G360F__2016-12-17_10.37.55.nvm" Backuping NVM ... done Time used : 17 min 52 s Prepare environment ... Backup EFS ... C:\Program Files (x86)\BST\backup\samsung\efs\SM-G360F\EFS_samsung_SM-G360F__2016-12-17_10.56.28.zip ok Prepare environment ... Backup EFS ... C:\Program Files (x86)\BST\backup\samsung\efs\SM-G360F\EFS_samsung_SM-G360F__2016-12-17_10.57.21.zip ok Wiping EFS ... ok Reboot device to NORMAL mode ... Re-scan device before any operation please Time used : 1 min 0 s Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.2 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G360F Hardware: QCOM Mode: normal Bypass MSL ... done Time used : 7.3 s Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Repair network … done |
