I9300i network problem after write super imei By BST one i9300i (S3 Neo_android 4.4.4) with not registered network after repair imei i do write defualt efs_Done write defualt super imei 1/2_Done repair 3g _Done imei ok but still not registered on network error after call Help BST TEAM Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300I Hardware: QCOM Mode: normal Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300I Hardware: QCOM Mode: normal Detect 1 USB devices not install driver Repair 3G network ... done Reboot device to NORMAL mode ... Re-scan device before any operation please |
i do write defualt efs_Done write defualt super imei 1/2_Done repair 3g _Done imei ok but not registered on network problem after repair 3G |
Help pls pls pls pls |
no solution yet bro no replay by supporter |
Why no reply by supporter???!!! :confused::(:eek::confused: |
try to write nvm tested |
this topic not for OCTOPLUS |
just writ good nvm and yr problem will solved |
Just Flow The Post Than Do Step By Step http://forum.gsmhosting.com/vbb/10607642-post391.html Br;) Palash Ahammad |
