BST / BSTPro Dongle BestSmartTools Official Support Section |
06-25-2015, 18:30 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: FLAT EARTH
Member: 1295624 Status: Offline Thanks Meter: 152 | ii747m 4.4.2 could not unlock [ANSWERED] Serial : Active User: yamobil PL2303 : 3.4.48.272 2013-02-05 (OK) Best Smart Tools, Load OK. Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Device Info (UART) ... failed Device Info (MTP) Model: SGH-I747M IMEI: 354524053076866 PDA Version: I747MVLUFNE6 Phone Version: I747MVLUFNE6 CSC : I747MOYBFNE6 CSC Version: I747MVLUFNE6 Time used : 40.0 s Device Info (UART) ... failed Device Info (MTP) Model: SGH-I747M IMEI: 354524053076866 PDA Version: I747MVLUFNE6 Phone Version: I747MVLUFNE6 CSC : I747MOYBFNE6 CSC Version: I747MVLUFNE6 Time used : 39.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Device Info (UART) ... failed Device Info (MTP) ... failed Time used : 0.1 s Scanning devices ... 0 found Device Info (UART) ... failed Time used : 8.7 s Device Info (UART) ... failed Time used : 8.7 s Device Info (UART) ... failed Time used : 8.7 s Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 18.1 s This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.1 s This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.0 s This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.1 s This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.1 s Had to use othe tool took me 3 seconds without changing usb settings in phone Port: 103 Model Selected : SGH-I747M Reading Info, wait... IMEI: 354524053076866 Start unlock, wait.... Job done, if phone not restart, restart manually Total Time: 00:00:03 is you method of unlocking different? |
06-26-2015, 06:26 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,745 | [This operation need QCDI interface....,]that's the bad thing in BST....!But you can unlock it Within Few Seconds,If you know How to use BST..... |
06-27-2015, 03:58 | #5 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,639 | Quote:
Enable phone QCDI interface as follo way please. 1. Type *#7284#, select PDA > UART 2. Click "Qualcomm USB Settings", select "DM+MODEM+ADB" P/S: Click "Help" button you will see this information sure!!! Best Regards GsmBest Team | |
06-27-2015, 05:59 | #6 (permalink) | |
Member: 1948608 Status: Offline Thanks Meter: 1,745 | Quote:
06-29-2015, 17:40 | #7 (permalink) |
Member: 1295624 Status: Offline Thanks Meter: 152 | after type *#7284# select PDA > UART pops up but Qualcomm USB Settings didnt show ,what simple minded person talk about me complaining? i used other tool to unlock without change any usb setting in phone ,so i ask again is phone detection method different in bst? simple question! |
