Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 10-10-2017, 12:40   #1 (permalink)
Member: 545021
Sonork: 100.1661580
Thanks Meter: 16
Mi a1 bootloop on september built [ANSWERED]
Here is the story
İ repaired imei on august built.
After i update september built my phone stuck on bootloop
When it is bootloop flash firmware with edl mode
Bootloop again
This is important it is bootloop with fresh firmware too
Only way is delete imei on edl mode. Then it starting proper.but imei gone. if restore qcn bootloop again
Old 10-10-2017, 12:53   #2 (permalink)
Member: 330082
Thanks Meter: 22
same problem ...
any solution ?
Old 10-10-2017, 12:57   #3 (permalink)
Member: 2750396
i have also same problem
Old 10-10-2017, 15:50   #4 (permalink)
Member: 1558552
Thanks Meter: 2
same for me too
i fix my bootlop exactly with you solution (delete ime edl mode). but this time i lost my imei. bst team pls help us
Old 10-10-2017, 19:33   #5 (permalink)
Member: 2343170
Thanks Meter: 50
baseband unknown please help me mi a1 efs or qcn upload
Old 10-10-2017, 22:55   #6 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,111
Unlock bootloader first and i explaine how to do
Old 10-11-2017, 02:07   #7 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,661
Originally Posted by elux227810 View Post
Here is the story
Bootloop again
Hi, elux227810
Give me follow info please.
Model Name:
MIUI version:
p/s: read phone info and post logs here please.
Best Regards
GsmBest Team
Old 10-11-2017, 10:57   #8 (permalink)
Member: 1558552
Thanks Meter: 2
model version is mdg2 (mi5x global or other name mi a1)
august built is ok
september buit bootloop after imei repair
[IMEI Repair]
> Backup phone original QCN before Repair IMEI or Erase IMEI/NVM.
1. Power on the phone and enable "USB Debugging" option.
2. Connect phone to pc via USB cables.
3. Dial(*#*#717717#*#*), Enable Qualcomm Diag port.
4. Press "Scan" button to confirm phone connected.
5. Press "EraseIMEI" (or Press "EraseNVM")
6. Repair IMEI
7. Repair Network
[Screen Lock]
1. Enter fastboot mode (install drivers if needed)
2. Press "OneKey Recovery"
3. Waiting phone enter recovery mode
4. Press "Scan" and then press "Reset Screenlock"
Tips: If you device Bootloader locked, have to unlock bootloader lock before Remove screenlock.
[Account Lock]
1. Enter Fastboot or EDL mode (install drivers if needed)
2. Press "Scan" and then press "Reset Account Lock"
Tips:
1).If phone locked still or Wifi not working, please do WIPE or flash firmware to fix problem.
2).If phone auto relock after online, please use "Patch Account Lock Relock" or "Disable Account Lock Relock" to fix problem
[Factory Reset]
2. Press "Scan" and then press "Factory Reset"
Scanning devices ... 1 found
dev[1] e21b6ad40504
Mode: normal
Hardware: qcom
Manufactory: XIAOMI
Model: MI A1
Checking environment ...
System Info
Display ID: N2G47H
System Ver: 7.1.2 REL
API Level: 25
Incremental: 7.9.21
Model: Mi A1
Brand: xiaomi
Device: tissot_sprout
Platform: msm8953
Product: tissot
Language:
Rigion:
SDCard Info
No sdcard detected
Device Info
Serial number: e21b6ad40504
Hardware: qcom
Bootmode: unknown
Bootloader ver: MSM8953_TISSOT1.0_20170921101112
Revision: 0
Main version:
Baseband ver: msm
GSM baseband:
GSM sim state: NOT_READY,NOT_READY
Get Bluetooth info failed
WiFi interface:
WiFi MAC: 00:0a:f5:50:14:10
WiFi state: COMPLETED
Root Access: No root
Get device information done , time used 6.08s
Time used : 6.1 s
Old 10-11-2017, 10:58   #9 (permalink)
Member: 1558552
Thanks Meter: 2
u are in china. just found mia1 and test it pls. there is no way imei repair on september built
Old 10-12-2017, 12:08   #10 (permalink)
Member: 1558552
Thanks Meter: 2
there is no any solution
Old 10-13-2017, 01:58   #11 (permalink)
EmeGSM-Wei's Avatar
Member: 133050
Thanks Meter: 6,661
Hello, Notilus
No have MI A1 in chinese market, MI5X have here, but its different factory code as we known.
MI 5X: tiffany
MI A1: tissot
If you have MIA1 imei working phone in your hands, i wanna remote check how to repair imei for this phone.
Best Regards
GsmBest Team
Old 10-13-2017, 09:22   #12 (permalink)
Member: 2767584
same problem with my a1 too
using it with august update without a problem.
google mixed things up with the new A/B system thing.
hope this will solved with the oreo update
Old 10-13-2017, 11:36   #13 (permalink)
mastana_dk's Avatar
Member: 804463
Thanks Meter: 77
Arrow
Xiaomi a1 efs resat after restart problem plz help me
Old 10-26-2017, 20:04   #14 (permalink)
Member: 2772096
Same problem. There is an update at ota. And i disabled updates. and now i am using it like that. No update.
Old 11-03-2017, 17:30   #15 (permalink)
sunny_cool's Avatar
Member: 138217
Thanks Meter: 16
reset efs in umt qc fire ur set is on but no imei
The Following User Says Thank You to sunny_cool For This Useful Post:
Page generated in 0.21611 seconds with 8 queries
