Mi Note 4 (2016100) pattern lock problem Mi Note 4 (2016100) pattern lock problem , phone is not going edl mode (by using mi special cable , edl mode bat or by shorting tp points ) when i connet mi special cable it shows charging plz tell how can i put phone into edl mode |
problem solved by changing usb cable i made a jumper and factory reset |
how to solve you this problem... i also same problem like you... i have try to all. and change cable.. please help thanks |
i changed my usb cable and made a jumper near battery when i connect usb cable it automatically on edl mode n then i did factory reset |
mi note 4 2016100 pattern lock solution 10000% :via recovery mode put your phone recovery mode connect to pc open Rb soft tool 1.6 tab to :recovery slide lode then format.. Report Post ;);) |
mi note 4 2016100 pattern lock solution 10000% :via recovery mode put your phone recovery mode connect to pc open Rb soft tool 1.6 tab to :recovery slide lode then format.. Report Post Thanks Bro Pattern Remove Done Problem Solve |
