BST / BSTPro Dongle BestSmartTools Official Support Section |
10-15-2015, 15:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: yemen
Member: 346934 Status: Offline Sonork: 100.1575675 Thanks Meter: 59 | problem with flash all samsung how are you i have problem with flash any samsung always massage : Connect to device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Time used : 0.2 s |
10-15-2015, 17:20 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | you dint described well your problem....! what is the Device status when you press Download Button..?it is on download Mode or Normal Mode...should be press scan button after connect device with D/load Mode in Bst....and than hit Flash tab.For Further info.press on Help tab....! |
10-15-2015, 17:25 | #3 (permalink) |
Freak Poster Join Date: Jul 2014 Location: EMMC
Member: 2228324 Status: Offline Thanks Meter: 79 | i think its about your driver problem!! here is step by step put phone in download mode conect to pc and run bst install driver select model and scan phone write flash its done |
