BST / BSTPro Dongle BestSmartTools Official Support Section |
10-12-2014, 23:58 | #1 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1489224 Status: Offline Thanks Meter: 7 | Not supported modem firmware Write Imei I9505? 1-Type * # 7284 # (but nothing comes out). 2 Type * # 0808 # and choose DM + MODEM + ADB. (perfect). 3 Type * # 9090 # and choose DM / DUM over HSIC. (out error) and the phone restarts. Connect the micro USB cable and dongle scan BST. get a window with 2 options: 1 (Samsung () () QCDI / MTP) 2 (Samsung I9505 Qualcomm / NORMAL.) choose Option No. 1. write imei connect the micro USB cable to the port QCDI interface and when I write Imei I get this: not supported modem firmware. that's not what happens or am doing any wrong step. friends could fix me or explain ???? Thank you all |
10-17-2014, 10:43 | #4 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1196625 Status: Offline Thanks Meter: 1 | how? i have n7105t same write imei modem not support i flash 4.3..pllease help Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-N7105T Hardware: Mode: QCDI,MTP Writing IMEI ... not supported modem firmware Time used : 0.3 s |
10-17-2014, 12:10 | #5 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | Quote:
But can tell you that you must get a older version of modem firmware, flash it and give it a try again. Also, try to give more info about your case because we can't help you with only info on model version... for example, tell us the firmware complete version so you can be advised on a supported modem version. But do all this in a new thread, so we don't mix up info related to i9505 with your n7105T handset! Best regards. | |
The Following User Says Thank You to Desirat For This Useful Post: |
10-18-2014, 07:23 | #6 (permalink) | |
Member: 1196625 Status: Offline Thanks Meter: 1 | Quote:
BIG THANKS YOU sir for solution and problem solved , i try downgrade 4.12 next write imei ...done.BST IS VERY2 GOOD SOLUTION FOR SMARTPHONE | |
10-27-2015, 23:04 | #7 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2478914 Status: Offline Thanks Meter: 1 | Hello. I have the same problem on my GT-I9505. My phone config : Display ID: KOT49H System Ver: 4.4.2 REL API Level: 19 Incremental: I9505XXUGNJ8 Model: GT-I9505 Brand: samsung Device: jflte Platform: msm8960 Language: en Rigion: GB Device Info SerialNumber: f5071ebf Hardware: qcom Model: jflte PDA Version: I9505XXUGNJ8 Phone Version: I9505XXUEMJ3 Bootloader ver: I9505XXUGNJ8 Ril HW ID:Not Acti Sales Code: ORX Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: ROOTED The modem is I9505_XXUEMJ3_JB_4.3_MODEM and I have try I9505XXUGNG2-MODEM before but same error : not supported modem firmware. Thnaks for your help |
