BST / BSTPro Dongle BestSmartTools Official Support Section |
12-31-2015, 16:41 | #1 (permalink) |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Samsung GT-I9003 FLASH AND IMEI REPAIR DONE Code: Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9003 Hardware: LATONA Mode: normal Load PDA "I:\SAMSUNG ALL\SAMSUNG FILE NEW\GT- I9003 M4\CODE_I9003DDKP3_CL882023_REV08_user_low_ship.ta r" ok Load Phone "I:\SAMSUNG ALL\SAMSUNG FILE NEW\GT- I9003 M4\MODEM_I9003DDKP4_REV_00_CL1072562.tar" ok Load CSC "I:\SAMSUNG ALL\SAMSUNG FILE NEW\GT- I9003 M4\GT-I9003-MULTI-CSC-ODDKPI_RST.tar" ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: DOWNLOAD Connect to device ... ok Device pit saved to E:\BST\backup\samsung\pit\GT-I9003\GT-I9003_2013-10-01_21.18.16.pit Write file normalboot.img ... ok Write file boot.bin ... ok Write file sbl.bin ... ok Write file param.lfs ... ok Write file system.rfs ... ok Write file cache.rfs ... ok Write file userdata.rfs ... ok Write file modem.bin ... ok Write file cache.rfs ... ok Flash completed Time used : 1 min 52 s Code: Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9003 Hardware: LATONA Mode: normal Checking environment ... ok System Info Display ID: GINGERBREAD System Ver: 2.3.6 REL API Level: 10 Incremental: DDKP3 Model: GT-I9003 Brand: samsung Device: GT-I9003 Platform: omap3 Language: en Rigion: GB Device Info SerialNumber: Hardware: latona Model: GT-I9003 PDA Version: I9003DDKP3 Phone Version: I9003DDKP4 Bootloader ver: UNKNOWN Ril Hw Version: MP 1.000 Sales Code: INU Model ID: I9003 Bluetooth addr: F0:08:F1:E6:C9:EA WiFi MAC: F0:08:F1:E6:C9:EB WI-FI is disabled Network [1]: GSM IMEI: 004999010640000 Root Access: No root Time used : 2.5 s Prepare environment ... need root access Start Get Root ... will try 6 methods Root with psneuter ... failed Root with root1 ... failed Root with exynos-abuse ... failed Root with root2 ... failed Root with zergRush ... .....failed Root with BST_SamRoot ... Prepare to root ... Reboot device to NORMAL mode ... ok Wait device ready ... ok Wait system boot ready ... ok Check root ... ok cleanup ... ok Getting permanent root ... ok Bypass MSL ... ok Update device ... ok Reboot device to NORMAL mode ... ok Wait device ready ... timeout Detect a new device but driver not installed Time used : 7 min 28 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9003 Hardware: LATONA Mode: normal Connect to device ... ok Device Authentication ... ok Writing IMEI ... ok, You need reboot device Time used : 1.8 s |
