SM-G800H super imei failed [ANSWERED] Log: Code: Сканирование устройства ... 1 готово |
Dont forget reboot phone after "Wipe EFS", and then repair imei. will be worknig sure. Best Regards GsmBest Team |
1) normal mode - wipe efs 2) reboot no bsi battery 3) super imei 1 MSL failed |
Code: Fw.Ver : BstKey V3.21 |
Contact me with my SKYPE ([email protected]) please, i will remote check and solve problem sure. Best Regards GsmBest Team |
failed same problem here connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... failed Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... failed thanks |
make sure that efs is reset?after reset the efs restart the phone and chk the imei if imei is there it means efs is not wiped...... |
Hello, 1st Wipe Cache & Wipe data In Recovery Then Reboot Phone. Then Scan & Wipe Efs Several Times Hope You Will Done ....... Regards, ------------------ GsmBest Team |
the same error. wipe cache and date did. Connect to device ... Device Authentication ... 1 failed with MSL thanks in advance |
I erased efs z3x box, only it turned out to erase, then I hooked up the phone without secondary contact to the bst through uart, he wrote me a new imei but not recorded cert issued by mistake, in the end I have a new phone with imei but without cert, now it does not catches network, efs fusion bst it does not record. but in the folder bst I found these 3 super imei folder sm G800F !!! I think this cert on the model G800F and we G800H !!! |
g800h does not detect with uart at all tried unplugging several times no response but reads on usb |
Regards !! |
You marked this tread: (Answered). But you did not describe how to restore IMEI. If i erased IMEI in z3x(your box not erase), after recording new IMEI was to register on the network.How to record IMEI2 in phone? Describe in detail or not deceive your users to support this operation. B.R. |
i have the same problem with s5 G800H when i connect uart cable: Device Authentication ... 1 failed with MSL how we can fix this? |
try this method 1 - factory reset 2 - root 3 - enable USB Debuging 4 - Run BST 5 - Select Scan 6 - write Default EFS 7 - unlock 8 - Select Super IMEI |
