Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 02-13-2018, 03:59   #1 (permalink)
Member: 2810324
Question sm-g891a not detected, screenlock not removed
v.3.38 advertises > Added SM-G891A {Flash,ScreenLock,Read/Write EFS,Read/Write QCN}
I installed v40 on windows 10/64, had to use zadig libusb since bst libusb driver install failed. bst program started correctly.
Remove screenlock instruction says to use microusb cable. However, scan does not detect the phone at all.
Second advice is to type code to use uart.. but code seem to have no effect in emergency mode dial screen -- did not accept it.
What am I doing wrong?
What windows version is best for this dongle software?
I do not wish to return it for refund, but I am stuck. Please help.
Old 02-13-2018, 04:18   #2 (permalink)
Member: 2810324
SM-G891a is a Samsung Galaxy S7 Active. ATT is the carrier. US phone. ATT rolled out update to 7/Nougat feb 2017. Thank you for asking.
Old 02-13-2018, 22:40   #3 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
how about you use a compatible windows like 7 for work,did you even install the phone drivers?
Old 02-14-2018, 22:58   #4 (permalink)
Member: 2810324
Thanks for the reply. Yes indeed I did install the phone drivers that came with the BST package. The install was completely normal other than the complaint the libusb install failed on a windows 10 /64 dell laptop. That same complaint happened on an Asus windows 7/64 system. I wonder what system is the one others are using since the v40 BST install seems to fail on both Win 7 and Win 10 for the usb drivers. Had to install the zadig libusb drivers for the software to identify the dongle and proceed at all.
Any other ideas?
Old 02-15-2018, 22:36   #5 (permalink)
Member: 2309595
Thanks Meter: 112
Enable ADB then use Gtalk method to remove screen lock
Old 02-15-2018, 23:02   #6 (permalink)
Member: 2810324
Thanks. Could you explain a bit more? Enable ADB in BST or on the phone? And if on the phone-- it won't even scan with the microusb cable. Also please some link explaining the gtalk method? Thanks again.
Page generated in 0.14523 seconds with 8 queries
