Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 11-28-2014, 12:09   #1 (permalink)
Member: 2110371
Thanks Meter: 20
sm g900h emergency calls only [ANSWERED]
sir i restore the imei of this fone and successful but insert my sim it search for the network and i want to call or check credit balance it will display NOT RIGESTERED ON NETWORK.
what should i do next it
regards
Old 11-28-2014, 12:12   #2 (permalink)
Member: 2110371
Thanks Meter: 20
regards
here is the log
Scanning devices ... 1 found
dev[1]
Manufactory: SAMSUNG
Model: SM-G900H
Hardware: UNIVERSAL5422
Mode: normal
Connect to device ...
Device Authentication ...
Writing IMEI ...
Writing IMEI certificate ... ok, You need reboot device
Old 11-28-2014, 13:08   #3 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,317
Hello,
First Dail *#0011# Then Check Imei CERT Fail/Pass ..?? If Fail Then Follow This :
> 1st Flash Your Phone
> Then Write Default EFS
> Then Restore IMEI ..
Before Flash You Can Try With Wtite EFS
http://www.4shared.com/file/3f744txW...53285063.html?
Regards,
_________
GsmBest Team
Old 11-28-2014, 14:37   #4 (permalink)
Member: 2110371
Thanks Meter: 20
Originally Posted by ..::CHAIN::.. View Post
Hello,
EFS_samsung_SM-G900H_353285063589527_2014-11-06_13.39.47 - Download - 4shared - MUKESH JHA
Regards,
_________
GsmBest Team
tnx for quick reply
1 imei cert is pass b4
2 after using efs u gave imei null/null
3 now use old efs then the fone return to old problem
but i have not flashed as u said
Old 11-30-2014, 08:07   #5 (permalink)
Member: 2117395
Thanks Meter: 6
SM-G900H cert file neaded plzzzzz helpppppp
Old 04-28-2016, 10:04   #6 (permalink)
Member: 1876831
Sonork: 100.1626615
Thanks Meter: 4,294,967,295
G900h cert file
http://forum.gsmhosting.com/vbb/f453...phone-1858891/
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.13846 seconds with 7 queries
