Stuck in EDL mode [ANSWERED] hello team, hope you can help. i try to forced edl mode redmi 3 phone, and it is success. here is log : Scanning devices ... 1 found dev[1] bfcda7f7 Mode: fastboot Hardware: ido Manufactory: UNKNOWN MID: Detect 1 USB devices not install driver Boot to EDL mode ... done %_General\AfterForceEdlNote% but when i try to flash with miflash tool can't find suitable ROM. already try redmi 3, redmi 3s ROM but always retun "reached the end of the file (0x80070026)". any other way to out from EDL mode without flashing ? PS : i try other redmi 3 flashing with this same way is work fine so i think problem is not in PC for ex driver and cable. thanks, hope you can help. best regards, FLAMINI |
Try to press and hold all buttons for 30 sec.. to get out of edl mde. b/r Kamal |
already try it, sir kamal. but still stuck in 9008 mode. thanks for reply b/r FLAMINI |
________ Br_Rizwan :) |
Him already answer you here: http://forum.gsmhosting.com/vbb/11985688-post4.html Best Regards GsmBest Team |
i think will come out of edl when all the battery gets drain regards suraj |
same for me Cant flash any rom, tried to detauch battery no success |
me too my redmi 3 stuck on edl after flash then reflash getting error br |
just use xiaomi factory cable and reflash the phone |
i use factory cable from box still getting error before condition good flashed use 64bit windows and disable driver signature that work finish 100 percent but phone stuck on edl then try to reflash won't work any solution please help me |
insert cable to the pc, push the button on the cable, connect the cable to the device, hold 3 buttons (+- and power) for 15 seconds, then release the button on the cable. After the device will shown on the device manager, flash the device Dont play with the drivers, software, just use the regular because its not the problem with the system , BST make wrong edl mode, so flash it via making right 9008 with the cable It will work for 100%, just try |
nokia ta-1021 exit edl mode solution pls help sir |
sir oppo a37f how exit edl mode...... i canect system to show qulcom........ detect canect tool then divise not found....... then remove battery again show...... press 3 button or power button then .... not remove & no power on how sol this problem.... help.... show image..... https://uploads.tapatalk-cdn.com/201...5b2d47dfae.jpg |
MI S2 MODEL M8103E6G does not exit edl mode phone cannot power on will boot to edl mode always. M please help....... |
mi note 5 does not exit edl mode phone cannot power on will boot to edl mode always any solution |
