⭐️02/05/2024⭐️Exynos 7884/7884B/7885/7904 - 54 models - No Root, Any Bit/Version/Knox New Exynos 7884/7884B/7885/7904 - 54 models - No Root, Any Bit, Any Version, Any Knox We haven't finished yet! This time we're thrilled to introduce support for
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device. The following devices are supported:
Available procedures:Restore / Store Backup, CSC Change, Repair Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (**), Unlock / Relock Bootloader (***) For more detailed information, please visit our Supported models page. If you'd like to see this working check out our videos:
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here and our Test Point Database to learn more. **:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available. ***: This is a beta feature, and it doesn't work on 100% of the devices, but our team is working on fully supporting the procedure. Software version: 39.27.1420 Release date: 02 may 2024 https://pics.chimeratool.com/logos/C...ture-v3-2x.png Visit our Webshop: https://chimeratool.com/shop Join our Telegram: https://t.me/chimeratool_offical Like us on Facebook: https://www.facebook.com/chimeratool Read our Help & Documentation: https://chimeratool.com/docs Get Support: https://chimeratool.com/contact GsmEasy Distributor: http://www.imei.us GsmServer Distributor: http://www.gsmserver.com |
wow chimera KING samsung tool :cool: very nice |
chimera is best tool in gsm markit |
Please add remove mdm lock on A042F via preloader mode in next update... |
you are the best and yes you are the king of samsung tools go ahead;). Her is the successful auto-detect and remove log of FRP S21 5G G991B U9 Code: Chimera Mobile Phone Utility version: 39.25.1235 @ 2024-05-02 Code: Chimera Mobile Phone Utility version: 39.25.1235 @ 2024-05-02 |
Fantastic update as always from Chimera team. Please add update for SM-T733 EDL mode functions |
Hello Team SM-A530F can u share test point ? |
thanksssssssssssssssssssssssss |
Please add remove mdm lock on A336b u8 |
Wow now you came to A10... that whats up always rocking chimera king of Exynos now i think we looking for imei repair and patch cert from eub please consider adding this Best Regards | Yoba |
Add A146b U2 android 14 Kg Lock |
i've one in hands for mdm remove |
