Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 06-28-2020, 20:18   #256 (permalink)
Member: 2961010
hello people from the Chimera group,
Even with the last update of June 26, I am not able to patch the s20, model g980f.
It gives error:
Unsupported modem. Install another firmware and try again.
Finished at local time: [06.27.20 13:33:40]
WorkID: 99131790
Please resolve the situation.
Greetings.
Old 06-29-2020, 12:28   #257 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 18,706
reply
Hi,
problem comes from your device's modem version.
Pleas install firmware with older modem and security patch version than you are able to complete the root and patch cert processes.
Best regards
Nicole
It gives error:
WorkID: 99131790
Greetings.
Old 06-29-2020, 14:58   #258 (permalink)
Member: 2961010
Originally Posted by Chimera Tool View Post
Hi,
Best regards
Nicole
are you solving a problem ???
I may be waiting for the new chimera update to be able to patch the cert.
Patch Certificate
27/06/2020
13:28:59
Get Info
27/06/2020
11:02:27
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G980F
Sales Code: ZTO
Country Code: Brazil
Timezone: America/Sao_Paulo
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Thu May 14 17:44:27 KST 2020
PDA Version: G980FXXU2ATE6 [may 2020, rev6]
Phone Version: G980FXXU2ATE3 [may 2020, rev3]
CSC Version: G980FOWO2ATE6 [may 2020, rev6]
Product Code: ZTO
HIDSw Version: G980FXXU2ATE6/G980FOWO2ATE6/G980FXXU2ATE3/G980FXXU2ATE6
Board Platform: UNIVERSAL990
Modem Platform: SHANNON5123
Serial Number: RF8N1263ZEA
Imei: 351578106761331
Unique Number: CE10193AF4C3695C1F7E
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT,LOADED
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-05-01
Preparing...
Checking root access.
The phone is rooted by: 3.19:EFTSU
Reading data...
The operation is in progress. Be patient! Do NOT disconnect the phone!
WorkID: 99131790
Old 06-30-2020, 18:54   #259 (permalink)
Member: 2156754
Thanks Meter: 4
good update thanks chimera team....
Old 07-10-2020, 18:10   #260 (permalink)
Member: 1787203
Lightbulb
Software version: 25.35.1140
Release date: 10 July 2020
New features and improvements:
  • Huawei: select fastboot device manually if it wasn’t recognised after reboot
  • Huawei: select files before you start the USB Firmware Update procedure
  • Huawei: manually add a board sw file (XML) for the Load Factory Fastboot procedure and Chimera will use the xloader and fastboot files from the package
  • Chimera: file download module refactor with improved stability and less prone to errors
Bugfixes:
  • Huawei: EF file extractor bugfix
  • Chimera: fixed a bug that could cause crash when closing procedure dialogs
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 07-10-2020, 18:45   #261 (permalink)
Member: 2447229
Thanks Meter: 9
Oppo flashing
From the updates I'm seeing I believe oppo latest phones will be possible soon with chimera tool
The Following User Says Thank You to @wankred For This Useful Post:
Old 07-10-2020, 18:51   #262 (permalink)
Member: 2171001
Thanks Meter: 107
Thanks for your update..how to enter Huawei com 0.1
And after reset frp how to exist com 0.1 mode without dissambly.
Old 07-10-2020, 19:42   #263 (permalink)
Member: 2870594
Sonork: yoandyveronika
Thanks Meter: 28
Hello friends, I am trying to repair imei Huawei p20 pro clt-l29 which is supported by Chimera and it does not always give me an error, could you help me please regards
Old 07-10-2020, 21:25   #264 (permalink)
jrbravo's Avatar
Member: 2545468
Thanks Meter: 161
Lord!
Bugfixes:
Sir don't forget the samsung brand please !!
Old 07-10-2020, 21:37   #265 (permalink)
Member: 2191903
thankyou for for best services... but pls we nned to surport samsung andriod 9 pie frp bypass ...
Old 07-11-2020, 00:31   #266 (permalink)
Member: 2208709
Sonork: brown36
credit taken
i unlock lg m250n my credit taken phone still locked
WORKID100063390
Old 07-11-2020, 02:05   #267 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 577
thanks
Old 07-11-2020, 09:49   #268 (permalink)
zeeshan ali 786's Avatar
Member: 2711874
Sonork: 100.650600
Thanks Meter: 448
always best team..good work
Old 07-11-2020, 13:56   #269 (permalink)
Member: 1975260
Hi i need combination files Samsung Galaxy S20 u3 .
Old 07-11-2020, 14:36   #270 (permalink)
Member: 2410302
Thanks Meter: 8
failed to send sig redmi note my note 10 m1910f4g
useing loader failed to send
modul qualcom generic and in xiaomi tab the same problem a week whit this problem... add xiaomi mtk flash
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12413 seconds with 7 queries
