Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 04-25-2024, 17:01   #2041 (permalink)
Member: 2686635
Thanks Meter: 94
Originally Posted by imei_info View Post
frp must be off to can work with qr code.
frp allready off but not working
only work in 1 device
3 devices not working this function
Old 04-25-2024, 18:12   #2042 (permalink)
Member: 3043825
Thanks Meter: 3
pls add lader g990b2 ................
The Following User Says Thank You to sundip12 For This Useful Post:
Old 04-25-2024, 20:48   #2043 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 588
Always best work...
Sir possible to imei repair add samsung qualcomm chips...
Like g770f......
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 04-26-2024, 00:46   #2044 (permalink)
karurosu316's Avatar
Member: 452143
Thanks Meter: 200
Please add Tecno phones with security 2024 please, reset MDM, and others
Thx
The Following User Says Thank You to karurosu316 For This Useful Post:
Old 04-26-2024, 06:45   #2045 (permalink)
Member: 2315113
please add samsung g781w lost mode
The Following User Says Thank You to gsmadel For This Useful Post:
Old 04-26-2024, 09:25   #2046 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 24,326
Dear User,
This solution is not very reliable, so it might not work on every device you try it. That is why we added it for free.
But, please try it again, as we have made some slight adjustments. If it still does not work, we do not have a suggestion for it.
Regards,
ChimeraTeam
Old 04-26-2024, 10:09   #2047 (permalink)
Member: 3044093
this solution works on android 14?
Old 04-26-2024, 10:35   #2048 (permalink)
Member: 536992
Thanks Meter: 88
Yes , works
I checked
The Following User Says Thank You to Serg5555 For This Useful Post:
Old 04-28-2024, 10:41   #2049 (permalink)
Member: 826204
Thanks Meter: 2
Qr method not working qr scan after connect wifi
and some second proccess after next option show
next after can't set up device
3 times try and other models also try but not working
only a54 device 1 time adb on
and all other 3 models same error not working fix plz thanks
Hello .
On A202f with U5 not working too
Old 04-28-2024, 10:56   #2050 (permalink)
Member: 826204
Thanks Meter: 2
would be nice team
Old 04-29-2024, 12:27   #2051 (permalink)
Member: 1787203
⭐️29/04/2024⭐️New Exynos9610/9611 - 35 models - No Root,Any Bit,Any Version,Any Knox
New Exynos9610/9611 - 35 models - No Root, Any Bit, Any Version, Any Knox
Get ready for a game-changing update!
This latest update is packed with cutting-edge features by introducing support for Exynos 9610 and Exynos 9611. Don't miss this out discover the variety of functions you can execute on your devices.
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device.
The following devices are supported:
  • Samsung Galaxy A50 (SM-A505F, SM-A505FM, SM-A505FN, SM-A505G, SM-A505GN, SM-A505GT, SM-A505N, SM-A505U, SM-A505U1, SM-A505W, SM-A505YN, SM-S506DL)
  • Samsung Galaxy A50s (SM-A507FN, SM-A5070)
  • Samsung Galaxy A51 2019 (SM-A515F, SM-A515U, SM-A515U1, SM-A515W, SM-S515DL)
  • Samsung Galaxy F41 (SM-F415F)
  • Samsung Galaxy XCover Pro (SM-G715FN, SM-G715U, SM-G715U1, SM-G715W)
  • Samsung Galaxy M21 (SM-M215F, SM-M215G)
  • Samsung Galaxy M30s (SM-M307F, SM-M307FN, SM-M3070)
  • Samsung Galaxy M31 (SM-M315F)
  • Samsung Galaxy Tab S6 Lite 10.4 (SM-P610, SM-P615, SM-P615C, SM-P615N, SM-P617)
Available procedures: Restore / Store Backup, Unlock / Relock Bootloader, CSC Change, Change Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset ()
For more detailed information, please visit our Supported models page.
If you'd like to see this working check out our videos:
  • CSC Change: EN / ES
  • Unlock / Relock Bootloader: EN / ES
  • Read Codes: EN / ES
  • ... or our two YouTube channel where you can find various educational content: ChimeraTool and ChimeraToolES.
Stay tuned! We'll continue tomorrow...
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here and our Test Point Database to learn more.
**:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available.
Software version: 39.24.1218
Release date: 29 april 2024
Old 05-06-2024, 16:21   #2052 (permalink)
Member: 867708
Thanks Meter: 3
Hello.
Can you please get me some info about any solution for Samsung Galaxy Z Fold 4 SM-F936B with operator's financial lock??
Is there any chance for it in near future??
May The Force Be With You )
Old 05-09-2024, 09:58   #2053 (permalink)
Member: 1787203
Dear User,
KnoxGuard remove is not supported on this device yet, we will try to add it, as soon as we find a solution for it.
Regards,
ChimeraTeam
Originally Posted by RadioActive83 View Post
Hello.
Old 05-09-2024, 12:56   #2054 (permalink)
Member: 1787203
Improved Huawei USB Firmware Update and new Samsung Qualcomm programmers
Huawei Improvements
The USB Firmware Update procedure has been enhanced to provide support for the latest phone models. This update, available exclusively from USB update mode, allows for the flashing of files from ZIP archives, offering a more streamlined and efficient process.
Samsung Qualcomm Improvements
More new programmers have arrived for Samsung Qualcomm!
The following models are supported:
  • Samsung Galaxy S10+ (SM-G975U - BIT 9)
  • Samsung Galaxy S21 Plus 5G (SM-G996U - BIT A)
  • Samsung Galaxy S21 Ultra 5G (SM-G998U - BIT A)
  • Samsung Galaxy S22 Ultra 5G (SM-S908N - BIT 3)
  • Samsung Galaxy S24 Plus (SM-S926U - BIT 1)
Bugfixes
  • Samsung Qualcomm: fixes were added for the Boot Repair procedure (available from EDL mode)
  • Samsung MTK: fixed a bug, which made the Root procedure disappear
  • Huawei: fixed a bug related to Huawei drivers on Windows 11 OS
  • Core: fixed a bug in the Authenticator sub-menu of the Settings page
Announcement
Samsung services will be unavailable from EUB mode between 11:00 and 12:00 (CET) on May 13th due to scheduled maintenance.
Software version: 39.33.2112
Release date: 09 may 2024
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 05-09-2024, 13:52   #2055 (permalink)
WINDA's Avatar
Member: 804772
Thanks Meter: 133
need support for samsung A05s kg lock sir yhx before
The Following User Says Thank You to WINDA For This Useful Post:
Page generated in 0.12143 seconds with 9 queries
