Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-29-2021, 10:13   #721 (permalink)
Member: 2973928
Thanks Meter: 263
team plzz add samsung all model 2021 repiar & patch.......
The Following User Says Thank You to blushis For This Useful Post:
Old 03-29-2021, 10:26   #722 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 24,626
reply
Hi there,
Sadly no, it is not supported yet. We will try to update it within a short time!
Best regads
Sab
Chimera Team
Originally Posted by bourrouhou View Post
oppo a5 2020 supported for flashing ?
Old 03-29-2021, 12:14   #723 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,349
Good Update Keep it up
Now G988B on Android 11 should be worked Imei Repair and Patch Cert right?
Old 03-29-2021, 14:04   #724 (permalink)
Member: 1787203
reply
Yes we do have reports that the users could do it with Android 11.
Old 03-30-2021, 14:20   #725 (permalink)
Member: 2211005
Sonork: no
chimera team plese update latest patech 2021 .samsung m215f u2
Old 03-30-2021, 16:15   #726 (permalink)
Member: 2345417
Thanks Meter: 9
Hello everyone
supported j600fn J600FNXXS9CTI2 to read codeS network CHIMERA TOOL
Old 03-30-2021, 16:38   #727 (permalink)
Member: 2147040
Did you try the latest version which released on 25/03/2021? Were you able to patch cert on Android 11? I have the same model with same PDA and CSC and having the same bootloop issue with android 11.
Originally Posted by kunzzz View Post
here my work id:
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G977N
Carrier ID: LUC
Sales Code: LUC
Country Code: KOREA
Timezone: Asia/Ho_Chi_Minh
Android Version: 11 [RP1A.200720.012] [SDK 30]
Build Date: Thu Feb 18 14:58:50 KST 2021
PDA Version: G977NKSU4FUBD [february 2021, revD]
Phone Version: G977NKOU4FUBD [february 2021, revD]
CSC Version: G977NOKR4FUBD [february 2021, revD]
Product Code: LUC
HIDSw Version: G977NKSU4FUBD/G977NOKR4FUBD/G977NKOU4FUBD/G977NKSU4FUBD
Board Platform: UNIVERSAL9820
Modem Platform: SHANNON50005100
Serial Number: R3CM40N67CA
Imei: 355401101053719
Connections: AT,MTP
Battery Status: 4.13V (83%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-03-01
Preparing...
Checking root access.
The phone is rooted by: 22.0:MAGISKSU
Reading data...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Patching certificate...
The phone must be started in recovery mode to be rooted!
To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power].
Without root the patchcert will not work!
Restarting phone in recovery mode...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Successfully finished.
Finished at local time: [03.27.21 13:21:29]
WorkID: 129250758
The Following User Says Thank You to faizi.ch For This Useful Post:
Old 04-02-2021, 07:19   #728 (permalink)
Member: 2782328
Thanks Meter: 6
a530f u15 imei repair is supported?
Old 04-02-2021, 11:01   #729 (permalink)
Member: 2782328
Thanks Meter: 6
A530F U15 is supported for imei repair? Thanks
Old 04-04-2021, 11:15   #730 (permalink)
Member: 2975718
yep I did it in latest version of Chimera. It said "Successfully finished" after patch, but my device keep reboot. So I think it's unable to patch cert now on Android 11.
Old 04-05-2021, 10:12   #731 (permalink)
Member: 1787203
reply
Dear User,
Please repeat the process. Reflash the device, and root it again. Do the IMEI REPAIR method once again, and after that make sure that you do the PATCH CERT one more time.
Best regards
Sab
Chimera Team
Old 04-06-2021, 15:43   #732 (permalink)
Member: 2576731
Thanks Meter: 100
MAR-LX2 FRP FAIL
PHONE ONLY BOOT TO RECOVER AND NO FIRMWARE OS TOOL
Chimera Mobile Phone Utility version: 28.05.1131 @ 2021-04-06
Removing Huawei account
Rebooting phone to factory mode
Changing to factory mode
Rebooting phone to USB update mode
Downloading ERECOVERY files
Flashing ERECOVERY files
Uploading data
Servicing the phone
Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently.
The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards.
Finished at local time: [04.06.21 15:43:19]
WorkID: 130304263
Old 04-07-2021, 10:34   #733 (permalink)
Member: 1787203
reply
Dear User,
As we see the Method was done successfully. What happened after the process? The Factory reset automatically started?
Best regards
Sab
Chimera team
Originally Posted by Nelsonlanga View Post
MAR-LX2 FRP FAIL
Uploading data
Servicing the phone
WorkID: 130304263
Old 04-07-2021, 16:35   #734 (permalink)
Member: 2576731
Thanks Meter: 100
Yes started but stop on recover not pass
Originally Posted by chimera tool View Post
dear user,
as we see the method was done successfully. What happened after the process? The factory reset automatically started?
best regards
sab
chimera team
not pass on recover mode sitll today i have done even hard reset
Old 04-08-2021, 20:16   #735 (permalink)
Member: 1787203
⭐️ 08/04/2021 #14 BiWeekly Update – Fixes and Improvements ⭐️
New features and improvements:
  • Huawei: HDLC communication is now less error sensitive (might affect Huawei's USB Firmware Update)
  • LG: added refined failure detection for procedures in LAF mode
Bugfixes:
  • Motorola: fixed a bug in FRP Remove procedure
  • MTK: various bugfixes (bootrom detection, MT6739 memory issues)
  • Core: fixed blinking dialog UI issue
  • Core: fixed a bug during closing inactive logs
Software version: 28.07.1427
Release date: 8 April 2021
Page generated in 0.12984 seconds with 9 queries
