Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 10-27-2023, 09:25   #1756 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,562
Dear User,
Please connect the phone in EUB mode using Test point.
Best Regards,
ChimeraTeam
Originally Posted by bourrouhou View Post
G981B NO DOWLOAD MODE NO RECOVERY
HOW GO EUB MODE
Model: SM-G981B
CSC Version: G981BOXM7DUE1 [may 2021, rev1]
AP/PDA Version: G981BXXU7DUE1 [may 2021, rev1]
CP/Phone Version: G981BXXU7DUE1 [may 2021, rev1]
Serial: RFCN20Q5ETE
IMEI: 354397
IMEI2: 35433
Product Code: AMO
Unique Number: CE012041154A859E1F7E
Android Version: 11
Network Lock Status: UNLOCK
FRP Lock Status: LOCK
Successfully finished.
Finished at local time: [10.26.23 19:35:59]
WorkID: 241004007
Old 10-27-2023, 09:35   #1757 (permalink)
Member: 1787203
Dear User,
It is not possible. You must do hardware Test point in this case.
Best Regards,
ChimeraTeam
Originally Posted by Rex View Post
Hi,
how about lost mode no download it's possible to change to EUB without TP?
The Following 2 Users Say Thank You to Chimera Tool For This Useful Post:
Old 10-27-2023, 09:40   #1758 (permalink)
Member: 1787203
Dear User,
Yes, this update is for serial number change (not IMEI) and you do not need to perform a hardware Test point for some devices to get into EUB mode.
We have not added S20 Plus for IMEI Repair in this update.
Best regards,
ChimeraTeam
Originally Posted by dijiahmet View Post
hi.
What exactly will this update do?
For example, will I be able to change the IMEI number of my S20 Plus device, which has received the latest update?
Can I reset the knox counter?
Old 10-27-2023, 11:30   #1759 (permalink)
Member: 1361371
Sonork: savior
Thanks Meter: 11
please how does this work because my own cracker does not connect as you said.
Old 10-30-2023, 10:30   #1760 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 210
But A145f not supported eub mode when i try to connect its disconnect itself
Old 10-31-2023, 07:11   #1761 (permalink)
Member: 2818969
Sonork: gsmmilat
Thanks Meter: 5
[B]Patch success but still ng...[B]
Chimera Mobile Phone Utility version: 37.42.1630 @ 2023-10-31
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G780F
Carrier ID: INS
Sales Code: INS
Country Code: India
Timezone: Asia/Dhaka
Android Version: 13 [TP1A.220624.014] [SDK 33]
Build Date: Tue Jul 4 22:51:19 KST 2023
PDA Version: G780FXXSDFWG1 [july 2023, rev1]
Phone Version: G780FXXSDFWG1 [july 2023, rev1]
CSC Version: G780FODMDFWG1 [july 2023, rev1]
Board Platform: UNIVERSAL990
Modem Platform: SHANNON5123
Imei: 861999456353458
Battery Status: 3.79V (50%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2023-07-01
Em Did: 2009750D03362011
Patching certificate...
The operation is in progress. Be patient! Do NOT disconnect the phone!
About 5-20 seconds after the phone has started, check the imei status.
You can check the status of imei by using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Finished at local time: [10.31.23 11:53:05]
WorkID: 241632190
File Type: jpg Screenshot_20231031_121015_Service mode RIL.jpg (366.2 KB, 4 views)
Old 11-01-2023, 04:15   #1762 (permalink)
Member: 1787203
Dear User,
For this issue, we only have one solution and that is to try it again with different firmware and root versions.
Best Regards,
ChimeraTeam
Model: SM-G780F
Carrier ID: INS
Sales Code: INS
Country Code: India
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
WorkID: 241632190
Old 11-01-2023, 08:56   #1763 (permalink)
rashidmohamm's Avatar
Member: 1648903
Thanks Meter: 168
supported,removed frp eub mode
driver problem
FRP Remove
Finished at local time: [10.25.23 11:14:30]
WorkID: 240749591
Old 11-02-2023, 12:16   #1764 (permalink)
Member: 1787203
Exclamation Major Samsung Qualcomm updates & Halabtech collaboration
⭐️⭐️We are excited to introduce a significant collaboration with Halabtech. ⭐️⭐️
With the new Halabtech Downloader, Chimera users can now seamlessly browse Halabtech's vast database of mobile phone firmware directly within our software interface.
Looking for the latest firmware for a particular phone model?
It's now just a few clicks away, allowing you to search, find, and initiate downloads using links from Halabtech.
To access this exclusive feature, ensure you purchase the Halabtech addon available in our webshop. Head over to our homepage to enhance your Chimera experience today!
Improvements and fixes - Samsung
  • UI fix on Boot Repair panel, when the phone is a virtual device
  • We're trying to make the Store / Restore backup function safer by creating an automatic backup of partitions which are going to be affected by the Restore backup procedure and were never been backed up before
  • Fixed multiple bugs in the rooting solution of Chimera (mainly SAR 'system-as-root' phones, and phones with init_boot partition were affected)
Improvements and fixes - Generic Qualcomm
  • FRP Remove procedure was improved by using a better lookup algorithm for finding the FRP partition
  • New Qualcomm programmers were added, which made the following procedures available:
    FRP Remove, Store/Restore backup, Update Firmware, Advanced Flash, Factory Reset for the following models:
    • Samsung Galaxy Z Flip 4 5G (SM-F721B)
    • Samsung Galaxy Z Flip 5 5G (SM-F731B, SM-F731U)
    • Samsung Galaxy Z Fold 2 5G (SM-F916U)
    • Samsung Galaxy Z Fold 3 5G (SM-F926B)
    • Samsung Galaxy Z Fold 4 5G (SM-F936U)
    • Samsung Galaxy Z Fold 5 5G (SM-F946U)
    • Samsung Galaxy S20 Lite 5G (SM-G781U, SM-G781V)
    • Samsung Galaxy S10e (SM-G970U)
    • Samsung Galaxy S10 (SM-G973U)
    • Samsung Galaxy S10 Plus (SM-G975U)
    • Samsung Galaxy S20 5G (SM-G981U)
    • Samsung Galaxy S20 Plus 5G (SM-G986U)
    • Samsung Galaxy S20 Ultra 5G (SM-G988U)
    • Samsung Galaxy S21 5G (SM-G991U)
    • Samsung Galaxy S21 Plus 5G (SM-G996U)
    • Samsung Galaxy S21 Ultra 5G (SM-G998U)
    • Samsung Galaxy Note10 (SM-N970U)
    • Samsung Galaxy Note 10 Plus (SM-N975U)
    • Samsung Galaxy Note 20 5G (SM-N981U)
    • Samsung Galaxy Note 20 Ultra 5G (SM-N986U)
    • Samsung Galaxy S22 5G (SM-S901U)
    • Samsung Galaxy S22 Ultra 5G (SM-S908E, SM-S908U)
    • Samsung Galaxy S23 5G (SM-S911B)
    • Samsung Galaxy S23 Plus 5G (SM-S916B)
    • Samsung Galaxy S23 Ultra 5G (SM-S918B)
  • Fixed a bug, where we were detecting phones connected in EDL mode as Huawei devices
  • Fixed an issue where Chimera encountered an error while attempting to write data to the flash chip because the size of the data was not aligned with the flash chip's sector size.
For exact model list you can visit our Supported models page at https://chimeratool.com/en/models .
Software version:37.45.0821
Release date: 02 november 2023
Old 11-02-2023, 13:24   #1765 (permalink)
Member: 226845
Thanks Meter: 82
Add a705mn A70 new programmer for EDL flashing
Existing programmer seems to be old. Sadly, I cannot check phone´s binary, it reboots and does not allow to enter recovery/ download mode.
Regards.
Old 11-02-2023, 13:44   #1766 (permalink)
Member: 2821366
Thanks Meter: 7
f926b need edl test point
Old 11-02-2023, 13:49   #1767 (permalink)
Member: 328688
Thanks Meter: 2,310
pleaz add other qcomm Samsung i A235F NO loader found
Old 11-02-2023, 14:30   #1768 (permalink)
Member: 2312431
Thanks Meter: 21
I need test point for Samsung Galaxy Z Fold 3 5G (SM-F926B)
Old 11-02-2023, 16:20   #1769 (permalink)
Member: 2311393
Thanks Meter: 15
Hi:
Where can I find the mentioned addon for HalabTech?
Thanks in advance
Old 11-02-2023, 16:26   #1770 (permalink)
Member: 2311393
Thanks Meter: 15
I found it, is on the Shop section on the Chimera website ... But €53 per year for an addon?!?!?!?! Or is it a Platinum package adquisition included? Could you please elaborate on this...
Thanks in advance...
Originally Posted by JasMyXelf View Post
Hi:
Thanks in advance
Page generated in 0.11739 seconds with 9 queries
