![]() | #2208 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,771 | Samsung a72 a725f u8 not supported Chimera Mobile Phone Utility version: 40.52.0937 @ 2024-09-04 Identify qualcomm device Preparing Qualcomm programmer Gathering device info Downloading Qualcomm programmer Internal communication timeout error. Selected programmer not suitable Please restart the phone in ADB mode and run a 'Get Info' procedure. Finished at local time: [09.04.24 23:50:43] WorkID: 303902801 |
![]() | #2209 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 278 | today i try Xiaomi Redmi 13C reloader interface disconnected Chimera Mobile Phone Utility version: 40.52.0937 @ 2024-09-05 Change to bootrom mode Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected Failed to connect to the phone, please reboot the phone to bootrom mode so that we can try again! Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! The procedure has been canceled. Finished at local time: [09.05.24 09:19:16] WorkID: 303926753 |
![]() | #2211 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2017 Location: Pakistan
Member: 2761588 Status: Offline Thanks Meter: 36 | REDMI 13C Chimera Mobile Phone Utility version: 40.52.0937 @ 2024-09-07 Change to bootrom mode preloader interface detected. Preloader interface disconnected preloader interface detected. Failed to connect to the phone, please reboot the phone to bootrom mode so that we can try again! Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! Preloader interface disconnected preloader interface detected. Preloader interface disconnected Try different method... Preloader interface detected Preloader interface detected MTK bootrom mode is inaccessible on this device Finished at local time: [09.07.24 18:55:33] WorkID: 304606612 |
![]() | #2213 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,562 | Dear User, Currently, we do not have a loader file for this device. If you have a loader that is compatible with it, you can use that, otherwise you will have to wait until we manage to acquire it. Regards, ChimeraTeam Quote:
![]() | #2214 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,562 | Dear User, As we see you managed to connect the device after a retry. Regards, ChimeraTeam Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
![]() | #2215 (permalink) |
Member: 2761588 Status: Offline Thanks Meter: 36 | redmi 13c connect perfectly , can i repair without hardware? Chimera Mobile Phone Utility version: 40.52.0937 @ 2024-09-07 Change to bootrom mode preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected Failed to connect to the phone, please reboot the phone to bootrom mode so that we can try again! Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! Try different method... Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Preloader interface detected Identifying... Reading data from the phone... Autodetect features Reading data from the phone... Reading data from the phone... IMEI not found Supported procedures: Advanced Flash Factory Reset Store/Restore Backup Factory Reset Update Firmware FRP Remove Get info Root Finished at local time: [09.07.24 19:09:00] WorkID: 304608256 |
![]() | #2216 (permalink) |
Member: 2761588 Status: Offline Thanks Meter: 36 | samsung A1560 Frp Failed Chimera Mobile Phone Utility version: 40.57.1309 @ 2024-09-12 Printing phone history Device Info 9/12/2024 6:45 AM Get Info 9/12/2024 6:43 AM Remove FRP 9/7/2024 1:04 PM Reboot 9/7/2024 1:04 PM Device Info 9/7/2024 1:02 PM Removing factory reset protection... Waiting for download mode. Connected Saving PIT data to file: C:/Program Files (x86)/Chimera/Backup/Samsung/Samsung Galaxy A15 5G/Samsung Galaxy A15 5G-mtk-frp-2024-09-12-114535.pit Restarting the phone... Unable to finish. Operation failed Finished at local time: [09.12.24 11:45:36] WorkID: 305929061 |
![]() | #2217 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,562 | Dear User, Samsung closed the exploit on the device, we do not have a solution for it, currently. Regards, ChimeraTeam Quote:
![]() | #2218 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 25,562 | ⭐️13/09/2024⭐️Samsung Qualcomm Reset Battery Status and Other Improvements Samsung Qualcomm Reset Battery Status and Other Improvements New Samsung Qualcomm Procedure Added new Reset Battery Status procedure (available from EDL mode), which can be used to reset the battery charge cycle count after changing the battery of the phone. Samsung Qualcomm Improvements The following models are now supported:
On the aforementioned devices, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status. For more detailed information, please visit the Supported Models page. Generic MTK Improvements The following devices are now supported:
The following procedures might be available for all MTK devices: Root, Repair MEID, Remove Warnings, Patch IMEI, Repair IMEI, Remove FRP, Update Firmware, Factory Reset, Network Factory Reset, Unlock/Relock Bootloader, Restore/Store Backup, Advanced Update Firmware. For a comprehensive list of procedure details, please visit the Supported Models section of our site. Generic Qualcomm Fixes Fixed erroneous data reading operations for Qualcomm devices. *: The solution works until the February 2024 security update. Software version: 40.60.1601 Release date: 13 september 2024 |
![]() | #2219 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Dominican Republic Age: 41
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 76 | Quote:
need loader n986w bit 9 any test | |
