Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 08-02-2021, 10:35   #961 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,561
reply
Dear User,
What do you mean with the Computer Crash? What happens exactly? Do you get any error message?
Best regards
Sab
Chimera Team
Originally Posted by Leonelle View Post
Hello...
Each time I try to Factory Reset LG G6 (LG-H873) using the new method the computer crashes and the phone boots into download mode.
I'm not able to take the Work ID because of the computer crashes.
I'm using Windows 10 (21H1) x64
Thanks
Old 08-02-2021, 10:36   #962 (permalink)
Member: 2119579
Thanks Meter: 44
The computer brings blue screen with error code then restarts.
I'll try do this on Windows 7 and feed you back
Sorry, but I'm trying to do Network Factory Reset using new method
Old 08-02-2021, 10:40   #963 (permalink)
Member: 1787203
reply
Dear User,
Can you please tell me a WORK ID from the process? So we can check it.
Best regards
Sab
Chimera Team
Originally Posted by abayoma View Post
Samsung A12 patch error please fix
Old 08-02-2021, 11:35   #964 (permalink)
Member: 18782
Thanks Meter: 11
hi there
the samsung a21s unlock issue still not fixed, any idea when?
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A217F
Carrier ID: TLP
Sales Code: TLP
Country Code: Australia
Timezone: Australia/Sydney
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Mon Feb 22 19:00:10 KST 2021
PDA Version: A217FXXU5BUB4 [february 2021, rev4]
Phone Version: A217FXXU5BUA2 [january 2021, rev2]
CSC Version: A217FOLM5BUB4 [february 2021, rev4]
Product Code: TLP
HIDSw Version: A217FXXU5BUB4/A217FOLM5BUB4/A217FXXU5BUA2/A217FXXU5BUB4
Board Platform: UNIVERSAL3830
Modem Platform: SHANNON318
Serial Number: RF8R205KHNE
Imei: 352135140253954
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2021-01-01
Em Did: 20023777BAA77111
Reading codes...
Checking required conditions.
Switching to upload mode. Be patient! Do NOT disconnect the phone!
Read codes failed
Finished at local time: [08.02.21 20:32:38]
WorkID: 144624658
Old 08-02-2021, 13:33   #965 (permalink)
Member: 1787203
reply
Dear User,
We do not have exact release dates for the updates but of course we will inform every user once we can do some fixes.
Best regards
Sab
Chimera Team
Originally Posted by shockboy View Post
hi there
Model: SM-A217F
Carrier ID: TLP
Sales Code: TLP
Product Code: TLP
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Reading codes...
Read codes failed
WorkID: 144624658
Old 08-12-2021, 22:26   #966 (permalink)
Member: 1787203
12/08/2021 #32 BiWeekly Update - Fixes and Improvements
Samsung: added Repair IMEI and Patch Cert for MTK models:
  • Galaxy A01 Core (SM-A013F/G/M)
  • Galaxy A12 (SM-A125F/M/N/W)
  • Galaxy A31 (SM-A315F/G/N)
  • Galaxy A32 (SM-A325F/M/N)
  • Galaxy A41 (SM-A415F)
  • Galaxy M01 Core (SM-M013F)
  • Galaxy M01s (SM-M017F)
  • Galaxy M02 (SM-M022F/G/M)
Huawei: added Load Factory Fastboot procedure for phones with
  • Kirin 990
  • Kirin 990 5G
  • Kirin 820
  • Kirin 985
  • Kirin 710A
It can be used to do Repair Recovery and fix bootloop issues.
New features and improvements:
  • Core: fixed a bug when changing phone brands
  • Core: fixed multiple bugs which could cause application crashes
  • Core: improved Windows 7 compatibility
  • Vivo: Vivo MTK phones are fully handled by the Vivo module from now
  • Huawei: fixed a bug when using firmware archives for Repair Recovery
Software version: 29.33.1113
Release date: 12 August 2021
Old 08-12-2021, 22:26   #967 (permalink)
Member: 1787203
  • Kirin 990
  • Kirin 990 5G
  • Kirin 820
  • Kirin 985
  • Kirin 710A
Old 08-12-2021, 22:42   #968 (permalink)
Member: 2698409
Thanks Meter: 244
Do you mean you added factory fastboot for EMUI 11? Because EMUI 10 was always working
Old 08-13-2021, 00:11   #969 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
A12 android 11 and A022 Android 10 IMEI and cert patch disappeared when factory reset the phone is normal or abnormal and what's the solution or the phone need root permission to make it permanent thanks
Old 08-13-2021, 00:25   #970 (permalink)
Member: 1636627
Thanks Meter: 24
Please team need permanent patch solution for samsung mtk based phones. All samsung mtk based phone after reset phone goes to emergency calls only and need to pqtch certificate. Can i please make permanent patch certificate for samung mtk based phones. Thanks
Old 08-13-2021, 04:20   #971 (permalink)
Member: 2535317
Thanks Meter: 32
重大更新 .希望 支持 华为 710 710f 710a 到 990 高通 mtk 任何型号手机移除id 解bl 降级 .修复电池序列号 .
Old 08-13-2021, 08:59   #972 (permalink)
Member: 1787203
reply
Dear User,
The mentioned update/service is workable for every EMUI version as far as we tested. We even tried it on the Harmony OS. However, we would like to ask all of our users to post results, experiences regarding this method. We are curious about the works.
Best regards
Sab
Chimera Team
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 08-13-2021, 09:45   #973 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Please check A21s android 11 still fail to repair thanks
Old 08-13-2021, 09:50   #974 (permalink)
Member: 1787203
reply
Dear User,
The MTK patch cert is a bit different from the other Patch Cert methods. Yes, the device will send you back an NG status, but normally you will be able to make calls, and receive calls. Please try it. As far as we know the method won't be wiped out from the device with hard reset/firmware update.
However, obviously issues could appear. So if you won't be able to make any calls, then restore the original IMEI number and the Cert status will be changed.
Best regards
Sab
Chimera Team
Old 08-13-2021, 10:16   #975 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Hoo thank you for update
Page generated in 0.12649 seconds with 9 queries
