Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 11-14-2021, 14:08   #1096 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
A32 5G A326B Unknown baseband
Need solution and also imei not shows ................
Old 11-14-2021, 14:09   #1097 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
It happened after rooting mobile i flash full 4 firmware its still same...........
Old 11-14-2021, 15:21   #1098 (permalink)
Member: 448480
Thanks Meter: 11
Thank you chimra team......
The Following User Says Thank You to MAYEO For This Useful Post:
Old 11-15-2021, 11:36   #1099 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,569
reply
Dear User,
Sadly at the moment we do not have the necessary services to solve the mentioned problem on that device. Hopefully later on we can add the IMEI REPAIR and the PATCH CERT as well.
Best regards
Sab
Chimera Team
Old 11-15-2021, 12:21   #1100 (permalink)
Member: 706781
Thanks Meter: 15
dear chimera team oct2020 to nov2021 no patchcert update ????
Old 11-15-2021, 14:22   #1101 (permalink)
Member: 1787203
reply
Dear User,
We do not had updates for the Samsung module recently. We focused more on the MTK devices.
Best regards
Sab
Chimera team
Old 11-20-2021, 15:53   #1102 (permalink)
Member: 1787203
19/11/2021 #46 BiWeekly Update Summary - Fixes and Improvements
New features and improvements:
  • MTK: added support for MT6781 SoC type
  • Huawei: added Modify Oeminfo procedure for MTK phones
  • Core: improved stability of the firmware unpacker (used during procedures and in the utility section too)
Bugfixes:
  • Huawei: fixed a bug in Remove Huawei ID for MTK phones (previously it was unable to add screenlock/pinlock/fingerprint lock after a Huawei ID remove) [please let us know if it works]
  • Core: fixed a UI glitch when a connected phone doesn't have any procedures
  • LG: fixed a bug when doing Firmware Update from a KDZ file
Software version: 30.31.1318
Release date: 19 November 2021
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 11-20-2021, 18:06   #1103 (permalink)
ElBerryKM13's Avatar
Member: 1414809
Thanks Meter: 155
What's the latest device you added imei change functionality? I'm talking about a phone where you put any imei you want for as many times as you want. Thanks
*edit: not talking about samsung or patch cert. I want to buy a phone where you could change the imei easy but it has to be a phone released in the last year or two with VOLTE functionality
Old 11-20-2021, 20:55   #1104 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 498
Bugfixes:
Visit our Webshop: https://chimeratool.com/shop
Like us on Facebook: https://www.facebook.com/chimeratool
Read our Help & Documentation: https://chimeratool.com/docs
Get Support: https://chimeratool.com/contact
GsmEasy Distributor: http://www.imei.us
GsmServer Distributor: http://www.gsmserver.com
What Is The Solution For Them Who Can't Use Pin/Pattern/Screen Lock After Remove Huawei ID With ChimeraTool?
I Also Flashed But Still Same
Old 11-21-2021, 05:41   #1105 (permalink)
Member: 2973928
Thanks Meter: 263
Good update thnx team....
The Following User Says Thank You to blushis For This Useful Post:
Old 11-21-2021, 08:33   #1106 (permalink)
Member: 2908709
Thanks Meter: 4
SIR add plese remove huawei id y7p and p smart 2021
The Following User Says Thank You to lalamusasunny For This Useful Post:
Old 11-21-2021, 09:42   #1107 (permalink)
Member: 2665448
Sonork: innocentsoul008
Thanks Meter: 15
Bugfixes:
I am facing issues of connection with MTK phones. some times it is not connected in broom mode.
and it was not driver's issue because the same phone connects with other devices in broom mode.
Old 11-21-2021, 11:58   #1108 (permalink)
Member: 328688
Thanks Meter: 2,310
Bugfixes:
still same dont even remove id y5p
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 11-21-2021, 19:33   #1109 (permalink)
Member: 2948174
Sonork: 100.1602299
Thanks Meter: 40
Add spd Chinese cpu........
Old 11-22-2021, 11:09   #1110 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the report, we will forward your issue to the team for further investigation.
Best regards
Sab
Chimera Team
Page generated in 0.11811 seconds with 9 queries
