Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-10-2023, 15:10   #1636 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 21,768
reply
Dear hamdard2000,
At the moment no. We do not have a method for that. The ID removal will require Hardware TestPoint.
Best regards
Sab
Chimera team
Originally Posted by hamdard2000 View Post
can we remove huawei frp account without testpoint
The Following 2 Users Say Thank You to Chimera Tool For This Useful Post:
Old 03-10-2023, 15:33   #1637 (permalink)
telmagdy's Avatar
Member: 1494964
Sonork: 100.100.573
Thanks Meter: 169
thank u chimera team ... good update
Old 03-10-2023, 15:40   #1638 (permalink)
Member: 1787203
reply
Dear telmagdy,
Thank you for the feedback! If you have any requests for our developers, please let us know it.
Best regards
Sab
Chimera team
Old 03-14-2023, 03:47   #1639 (permalink)
Member: 2987633
good update team...........
Old 03-14-2023, 13:27   #1640 (permalink)
Member: 1787203
reply
Dear Mobi,
Thank you for the positive feedback!
Best regards
Sab
Chimera team
Old 03-18-2023, 10:01   #1641 (permalink)
Member: 276432
Thanks Meter: 65
oppo reno 7 pro 5g can not fix imei because can force to berom how to do it ?
Old 03-18-2023, 13:28   #1642 (permalink)
Member: 2949612
Please work on vivo preloader
The Following User Says Thank You to karamGSM For This Useful Post:
Old 03-20-2023, 15:06   #1643 (permalink)
Member: 1787203
reply
Dear User,
The OPPO IMEI REPAIR is not supported at the moment. You can try to connect the device to the tool, because in that case the Tool will run an AUTODETECT method on it, which will show you what services can we do for it, and it will provide us some information about the device, which will help our work in the future. But we do not have an exact solution for that.
Best regards
Sab
Chimera team
Old 03-21-2023, 21:17   #1644 (permalink)
Member: 2727333
Originally Posted by Chimera Tool View Post
Dynamic Harmony Cable by Chimera
Thanks to chimera team for gsm market. I dont understand this point "
4. Kill this via-connection. Cut it with a scalpel or drill over it."
Is it just cut or drill this point or make test point to ground on processing? What the meaning to drill this point?
Old 03-23-2023, 07:22   #1645 (permalink)
Member: 1787203
reply
Dear Rickyman,
You do not need a complex tool to break this connection through via. Turn a sharp knife or scalpel a few times when the tip is inserted to the via whole. This way you remove permanently the original connection between the LED and its driver. The purpose is to reuse the LED for a different function - see further steps
You do not need to drill through the via
Theoretically, you can drill through to kill the connection, but unless you have a properly sized drill bit, we do not recommend this.
Best regards
Sab
Chimera team
Old 03-26-2023, 22:00   #1646 (permalink)
Member: 1787203
#12 BiWeekly - Oppo / Samsung / MTK / Core: New functions and fixes
New features and improvements:
  • MTK: added a new generic Advanced Flash procedure to phones with MTK SoC (similar to Qualcomm's)
  • Samsung MTK: added a new FRP Remove procedure which can be used from Download Mode and Modem Mode
  • Oppo: added a new Firmware Update function which you can use to install OTA update from the Oppo server
  • Chimera Utility: improved OPS file support in the Firmware Extractor
Bugfixes:
  • MTK: fixed a bug which made impossible to start the Bootloader procedure for various brands from ADB mode
  • Motorola: fixed a link on the Firmware Update panel
  • Core: fixed a UI bug which could occur on computers with Intel VGA
Software version: 35.21.1519
Release date: 24 March 2023
Old 03-27-2023, 05:11   #1647 (permalink)
Iftakhar Rajper's Avatar
Member: 2705849
Thanks Meter: 644
Great team,good update keep it up....
The Following User Says Thank You to Iftakhar Rajper For This Useful Post:
Old 03-27-2023, 05:15   #1648 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,360
plz add the world first update
Old 03-27-2023, 12:08   #1649 (permalink)
Member: 1787203
reply
Dear Haji,
We will try to improve the tool with methods that are unique, however, we need time to develop such services.
Best regards
Sab
Chimera team
Old 03-27-2023, 18:23   #1650 (permalink)
Member: 731353
Thanks Meter: 249
is oppo cph2067 flashing supported ?
Page generated in 0.11651 seconds with 9 queries
