![]() | #711 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2018 Location: ajah lagos
Member: 2838160 Status: Offline Thanks Meter: 8 | job not done credit deducted Good great team please job failed but deduct my credit pls help me out Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-26 Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Carrier ID: EUX Country Code: UK Timezone: Africa/Lagos Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Oct 5 19:16:03 KST 2020 PDA Version: A515FXXU4CTJ1 [october 2020, rev1] Phone Version: A515FXXU4CTJ1 [october 2020, rev1] CSC Version: A515FOXM4CTJ1 [october 2020, rev1] Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Imei: 353194566961839 Imei2: 354558596961838 Network Type: GSM SIM Status: ABSENT,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-10-01 Reading codes online... The operation is in progress. Be patient! Do NOT disconnect the phone! Read codes failed. Finished at local time: [03.26.21 20:50:19] WorkID: 129178447 |
![]() | #714 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,724 | reply Hi there, Which model variant exactly? The Samsung Galaxy J5 does have 9 model variants, that we can support. https://chimeratool.com/en/models#q=J530 Best regards Sab Chimera team |
![]() | #715 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 25,724 | reply Hi there, Although the mentioned phone - a716u- is supported by the Chimera Tool: https://chimeratool.com/en/models#q=a716u The unlock process is not added for the T-mobile version. Best regards Sab Chimera Team |
![]() | #717 (permalink) |
Junior Member Join Date: Dec 2020 Location: Vietnam
Member: 2975718 Status: Offline Thanks Meter: 1 | today I tried to patch cert in model sm-g977n OS11 bit 4 and it had boot loop, then I try in os10 with autoroot and Get this error message: ODIN MODE (AVB Fail) recovery: Error validating footer. (0) recovery: Error verifiying vbmeta image: invalid vbmeta header (6) CUSTOM RECOVERY. OS11 with autoroot get it too. please help me with it. |
![]() | #718 (permalink) |
Member: 2975718 Status: Offline Thanks Meter: 1 | here my work id: Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G977N Carrier ID: LUC Sales Code: LUC Country Code: KOREA Timezone: Asia/Ho_Chi_Minh Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Thu Feb 18 14:58:50 KST 2021 PDA Version: G977NKSU4FUBD [february 2021, revD] Phone Version: G977NKOU4FUBD [february 2021, revD] CSC Version: G977NOKR4FUBD [february 2021, revD] Product Code: LUC HIDSw Version: G977NKSU4FUBD/G977NOKR4FUBD/G977NKOU4FUBD/G977NKSU4FUBD Board Platform: UNIVERSAL9820 Modem Platform: SHANNON50005100 Serial Number: R3CM40N67CA Imei: 355401101053719 Connections: AT,MTP Battery Status: 4.13V (83%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Preparing... Checking root access. The phone is rooted by: 22.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.27.21 13:21:29] WorkID: 129250758 |
The Following User Says Thank You to kunzzz For This Useful Post: |
