Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 04-30-2024, 13:51   #16 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,767
Dear User,
Can you tell us more about this network lock? Does the phone ask for codes? Or is it something special?
If you can share more information about this type of network lock, so that we can look into it.
Regards,
ChimeraTeam
Originally Posted by eumore79 View Post
Long time waiting for direct unlock solution for Smart Phiippines network locked.
hope to see it on next update
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 04-30-2024, 15:12   #17 (permalink)
Member: 2772373
Thanks Meter: 8
Hi do you have test point for note 9 N960F?
The Following User Says Thank You to HamedSooffee For This Useful Post:
Old 04-30-2024, 16:45   #18 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 505
Chimera always rocking good keep it up team please add bypass/remove mdm knox guard procedure using adb interface
Best Regards | Yoba
The Following User Says Thank You to eyobaaa For This Useful Post:
Old 04-30-2024, 16:49   #19 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 84
Originally Posted by Chimera Tool View Post
Dear User,
Can you try to run the KnoxGuard Patch procedure?
Best Regards,
ChimeraTeam
Printing phone history
Auto Detect
30/04/2024
3:46
p.*m.
Auto Detect
30/04/2024
3:45
p.*m.
Knoxguard Patch
29/04/2024
8:47
p.*m.
Auto Detect
29/04/2024
8:46
p.*m.
Unlock / Relock Bootloader
29/04/2024
8:45
p.*m.
Knox Guard Patch started
KnoxGuard patch warnings!
1) If device firmware is modified or reflashed, the KnoxGuard lock may return.
2) Over-the-air updates are blocked.
3) Wipes and factory resets are safe.
Successfully finished.
Finished at local time: [04.30.24 10:47:26]
WorkID: 273795163
yes boss, after run knox patch procedure phone show error VBMETA verification disabled bit is set... kg state still locked with oem off... I can't flash firmware, now condition phone is stuck in download mode VBMETA M315FXXU2BUH7
Old 05-01-2024, 05:03   #20 (permalink)
Member: 3033926
Thanks Meter: 12
Great update team,
Thanks for keeping on top of the game
The Following User Says Thank You to 060787 For This Useful Post:
Old 05-01-2024, 06:18   #21 (permalink)
Member: 2353766
Thanks Meter: 73
Again BOOM Update ...Fantastic Work done by Great Team
The Following User Says Thank You to WWRG For This Useful Post:
Old 05-02-2024, 11:29   #22 (permalink)
Member: 525940
Thanks Meter: 214
its hard doing mtk frp sometimes cannot success but if in other tools its easy
you must improve the mtk
Old 05-02-2024, 13:40   #23 (permalink)
Member: 1787203
Dear User,
Can you elaborate please? We would like to improve Chimera, but first we need to know your exact issue. Which phones have you tried to do?
Best Regards,
ChimeraTeam
Old 05-02-2024, 14:06   #24 (permalink)
Member: 1787203
⭐️02/05/2024⭐️Exynos 7884/7884B/7885/7904 - 54 models - No Root, Any Bit/Version/Knox
New Exynos 7884/7884B/7885/7904 - 54 models - No Root, Any Bit, Any Version, Any Knox
We haven't finished yet! This time we're thrilled to introduce support for
  • Exynos 7884
  • Exynos 7884B
  • Exynos 7885
  • Exynos 7904
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device.
The following devices are supported:
  • Samsung Galaxy A10e (SM-A102N, SM-A102U, SM-A102U1, SM-A102W, SM-S102DL)
  • Samsung Galaxy A10 (SM-A105F, SM-A105FN, SM-A105G, SM-A105M, SM-A105N)
  • Samsung Galaxy A20e (SM-A202F, SCV46)
  • Samsung Galaxy A20 (SM-A205F, SM-A205FN, SM-A205G, SM-A205GN, SM-A205S, SM-A205W, SM-A205YN, SM-S205DL)
  • Samsung Galaxy A30 (SM-A3050, SM-A3058, SM-A305F, SM-A305FN, SM-A305GT, SM-A305N, SM-A305YN, SCV43)
  • Samsung Galaxy A30s (SM-A307FN, SM-A307G, SM-A307GN, SM-A307GT)
  • Samsung Galaxy A40 (SM-A405FM SM-A405FN, SM-A405S)
  • Samsung Galaxy A8 2018 (SM-A530F, SM-A530W)
  • Samsung Galaxy A7 2018 (SM-A750C, SM-A750F, SM-A750FN, SM-A750N)
  • Samsung Galaxy Xcover 4 (SM-G398FN)
  • Samsung Galaxy J7 Duo (SM-J720F, SM-J720M)
  • Samsung Galaxy M10s (SM-M107F)
  • Samsung Galaxy M20 (SM-M205G, SM-M205M)
  • Samsung Galaxy M30 (SM-M305F, SM-M305M)
  • Samsung Galaxy Tab A 8.0 2019 (SM-P205)
  • Samsung Galaxy Tab A 10.1 2019 (SM-T515, SM-T515N)
  • Samsung Galaxy Tab A 10.1 2019 LTE (SM-T517, SM-T517P)
Available procedures:Restore / Store Backup, CSC Change, Repair Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (**), Unlock / Relock Bootloader (***)
For more detailed information, please visit our Supported models page.
If you'd like to see this working check out our videos:
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here and our Test Point Database to learn more.
**:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available.
***: This is a beta feature, and it doesn't work on 100% of the devices, but our team is working on fully supporting the procedure.
Software version: 39.27.1420
Release date: 02 may 2024
Visit our Webshop: https://chimeratool.com/shop
Join our Telegram: https://t.me/chimeratool_offical
Like us on Facebook: https://www.facebook.com/chimeratool
Read our Help & Documentation: https://chimeratool.com/docs
Get Support: https://chimeratool.com/contact
GsmEasy Distributor: http://www.imei.us
GsmServer Distributor: http://www.gsmserver.com
The Following 10 Users Say Thank You to Chimera Tool For This Useful Post:
Old 05-02-2024, 14:13   #25 (permalink)
Member: 1724300
Thanks Meter: 42
wow
chimera KING samsung tool
very nice
The Following User Says Thank You to sajad0789 For This Useful Post:
Old 05-02-2024, 14:24   #26 (permalink)
Crazy Poster
Member: 3041178
Thanks Meter: 12
chimera is best tool in gsm markit
The Following User Says Thank You to khalidsuper12 For This Useful Post:
Old 05-02-2024, 14:54   #27 (permalink)
Member: 1677653
Thanks Meter: 2,775
Please add remove mdm lock on A042F via preloader mode in next update...
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 05-02-2024, 14:57   #28 (permalink)
Member: 98928
Thanks Meter: 477
you are the best and yes you are the king of samsung tools go ahead.
Her is the successful auto-detect and remove log of FRP S21 5G G991B U9
 Chimera Mobile Phone Utility version: 39.25.1235 @ 2024-05-02
Identify
Connecting to the phone...
Gathering information...
Preparing phone...
Downloading required files...
Processing files...
Communicating with the phone...
Rebooting
This may take a while.
Be patient! Do NOT disconnect the phone!
Finished at local time: [05.02.24 11:08:35]
WorkID: 274074432
Auto Detect
5/2/2024
8:13
AM
FRP Remove
Finished at local time: [05.02.24 11:08:50]
WorkID: 274074529
The Following 2 Users Say Thank You to bavesore For This Useful Post:
Old 05-02-2024, 15:16   #29 (permalink)
Member: 1033301
Thanks Meter: 15
Fantastic update as always from Chimera team. Please add update for SM-T733 EDL mode functions
Old 05-02-2024, 15:54   #30 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,780
Hello Team SM-A530F can u share test point ?
Page generated in 0.21100 seconds with 9 queries
