06-13-2024, 15:54 | #46 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Minsk
Member: 536992 Status: Offline Thanks Meter: 88 | Quote:
Status KG - > Checking Chimera tool it worked without errors , but factory reset did not happen. I flashed firmware. When I connect Wi-Fi, mdm profile is loaded. | |
06-14-2024, 18:06 | #49 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: . Age: 36
Member: 400280 Status: Offline Thanks Meter: 84 | Quote:
The Following User Says Thank You to Medusin For This Useful Post: |
07-31-2024, 10:27 | #51 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Pakistan
Member: 2761588 Status: Offline Thanks Meter: 37 | SM-P205 Chimera Mobile Phone Utility version: 40.11.1429 @ 2024-07-31 Printing phone history Get Info 7/31/2024 9:20 AM Switching to download mode... The operation is in progress. Be patient! Do NOT disconnect the phone! Preparing phone... Downloading required files... We don't know your current firmware version parts, so before we can continue with this procedure please run a Firmware Update procedure on your device using the same firmware version as it currently has: P205DXS6AVB1. Unknown firmware version Finished at local time: [07.31.24 14:20:38] WorkID: 294473660 |
08-01-2024, 08:53 | #52 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,451 | Dear User, Please flash the device in Download mode and in about 1-2 hours you can try the Switch to EUB procedure. Regards, ChimeraTeam Quote:
11-21-2024, 03:28 | #54 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Kyiv, Ukraine Age: 44
Member: 2418465 Status: Offline Thanks Meter: 126 | https://chimeratool.com/en/docs/eub-...out-test-point if you can see SWITCH TO EUB, then it is supported without making TP, put your phone in download mode then switch to EUB, but it is supported to old samsung exynos based phones...only few are supported for switching to EUB mode, the normal process is thru TP |
The Following User Says Thank You to professorjazz For This Useful Post: |
12-17-2024, 15:10 | #55 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 661 | s921b u5 test point not working ??????????????????????? Quote:
01-12-2025, 14:42 | #56 (permalink) |
Freak Poster Join Date: Jul 2005 Location: uk Age: 45
Member: 163725 Status: Offline Thanks Meter: 137 | I have a problem removing MDM A20e (a202f) after removing MDM when I DO phone setup with the wifi I receive a message (Network error unable to connect to server) I NEED HELP PLEASE https://ibb.co/ckBj81X |
01-13-2025, 12:48 | #57 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,451 | Dear User, Try to change the KG status to checking, unlock the bootloader of the device and then flash a KG patched firmware on it. Regards, ChimeraTeam Quote:
