03-01-2021, 14:47 | #677 (permalink) |
Junior Member Join Date: Jan 2016 Location: pakistan
Member: 2516820 Status: Offline Sonork: 100.1673482 Thanks Meter: 2 | Chimera Mobile Phone Utility version: 27.65.1339 @ 2021-03-01 Printing phone history Patch Certificate 10/02/2021 10:28 am Patch Certificate 04/02/2021 2:32 pm Patch Certificate 04/02/2021 2:31 pm Patch Certificate 04/02/2021 2:30 pm Root/Unroot 04/02/2021 1:38 pm Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: MSR Country Code: Serbia Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Jun 8 20:27:40 KST 2020 PDA Version: J530FXXS7CTF1 [june 2020, rev1] Phone Version: J530FXXS7CTF1 [june 2020, rev1] CSC Version: J530FMSR7CTG1 [july 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58K43K020F Imei: 352717091277031 Battery Status: 3.83V (57%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [03.01.21 18:43:22] WorkID: 126529281 still not supported why????? |
03-01-2021, 16:11 | #678 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,928 | reply Hi there, Yes sadly that device was not updated in the recent times. We will try to do some fixed for it in the near future. Best regards Sab Quote:
03-02-2021, 15:48 | #680 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,928 | reply Hello, We would like to inform all of our users, that from now on, you can easily request any device -and service for it-, at our website. You do not have to write comments anymore. Let us show, how can you provide more work to our developers
Sab |
03-11-2021, 17:34 | #681 (permalink) |
No Life Poster Join Date: Nov 2020 Location: karachi Age: 29
Member: 2973928 Status: Offline Thanks Meter: 260 | Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Carrier ID: XSG Sales Code: INS Country Code: India Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Sep 10 18:57:36 KST 2020 PDA Version: A205FXXS9BTI3 [september 2020, rev3] Phone Version: A205FDDS9BTI1 [september 2020, rev1] CSC Version: A205FODM9BTI3 [september 2020, rev3] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RZ8M63BDGQV Imei: 351803111430726 Imei2: 351803111430783 Network Type: GSM SIM Status: ABSENT,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [03.11.21 21:26:54] WorkID: 127679494 kindly plzz add new security 2021 patch thnxx.. |
03-11-2021, 17:53 | #682 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,928 | ⭐️ 11/03/2021 #10 BiWeekly Update – Fixes and Improvements ⭐️ Improvements and bugfixes:
Huawei changes:
Samsung changes:
* By using this checkbox the phone should accept all firmware versions during USB Firmware Update procedure. It doesn't generally mean that it allows version downgrade, because the phone can have different checks against that. It is usually used to let the phone accept a different model's firmware after a model name change. ** The Modify Oeminfo's Convert to Dual SIM feature creates a backup of the phone's original SIM state value, before it does the modification. The backup can be restored with this procedure. Software version: 27.79.1138 Release date: 11 March 2021 |
03-11-2021, 19:00 | #684 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1952971 Status: Offline Thanks Meter: 2 | Printing phone history Demo Remove 03/11/2021 05:40 ب.ظ Rmm Remove 03/11/2021 04:59 ب.ظ Patch Certificate 03/11/2021 04:58 ب.ظ Knoxguard Remove 03/05/2021 05:18 ب.ظ Rmm Remove 02/23/2021 01:16 ب.ظ RMM Remove started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Carrier ID: THR Sales Code: DBT Country Code: Germany Timezone: Europe/Mariehamn Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Nov 5 22:15:25 KST 2020 PDA Version: G955FXXSBDTK1 [november 2020, rev1] Phone Version: G955FXXSBDTK1 [november 2020, rev1] CSC Version: G955FOXMBDTK1 [november 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J42F4JNT Battery Status: 4.19V (96%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Removing RMM... The operation is in progress. Be patient! Do NOT disconnect the phone! It seems, this unlock method is not supported by the phone. Unlock failed. Finished at local time: [03.11.21 21:27:16] WorkID: 127690115 |
03-12-2021, 10:55 | #687 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,928 | reply Dear User, Thank you for the report. We will investigate the issue , but most likely the problem is the device binary version. We will focus on the fix for sure. Best regards Sab Chimera Team Quote:
03-12-2021, 11:18 | #688 (permalink) |
Member: 2973928 Status: Offline Thanks Meter: 260 | Good work team plzz add samsung 2021 all binarys all model repiar & patch thnxx |
The Following User Says Thank You to blushis For This Useful Post: |
03-12-2021, 11:29 | #689 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,928 | reply Dear User, At here you can request any device, for any services: https://chimeratool.com/en/dev-support-request Please follow the steps, and the developers will receive your request. Best regards Sab Chimera team |
03-12-2021, 11:31 | #690 (permalink) | |
Insane Poster Join Date: Feb 2014 Location: Pakistan
Member: 2128717 Status: Offline Sonork: 1660827 Thanks Meter: 12 | Quote:
