02-14-2019, 11:06 | #362 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,110 | reply Hi, we are working on the huawei solution, but when we mentioned many times than before it takes lot of time, when it will be an easy process the solution already added by each one tool. At the moment nobody have not solution for the new security, you can be sure it is not accidental. Our goal to add the huawei solution as fast as we can. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
02-14-2019, 11:10 | #363 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 24,110 | reply Hi, please try with other firmware version. We tested the function and it is worked, naturally we checked the processes on the same devices and in a 95% of the processes the result successfully done. Best regards Nicole Quote:
02-14-2019, 11:10 | #364 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 24,110 | reply Hi, can we ask the work id of the processes please? With them we can offer solution. Best regards Nicole Quote:
02-14-2019, 11:16 | #365 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,110 | Info Dear Users, some important information: we faced with misunderstanding with that part of the update: *KNOX must be 0 KNOX must be 0 by the follow case ONLY: Added Unlock Online For Exynos Models*
In each other case the KNOX 0 not necessary!!!! Other info: When you have problem with a process, please send work id with the description of the problem. Unfortunately with the message with " not working" or "bro I have a problem" we can not get enough info. What we need for the fast and easy reply: 1. Short description of the problem 2. Work id of the problematic processes. |
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
02-14-2019, 11:51 | #367 (permalink) |
Freak Poster Join Date: Oct 2009 Location: IND TO RSA.
Member: 1143337 Status: Offline Thanks Meter: 104 | J5 Prime G570F Imei repair done BUT no network Chimera Mobile Phone Utility version: 20.22.2159 @ 2019-02-14 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: unknown Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Oct 29 19:28:09 KST 2018 PDA Version: G570FXXU1CRJ1 [october 2018, rev1] Phone Version: G570FXXU1ARA1 [january 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R28J223R9PX Imei: 35341708*** Battery Status: 3.77V (6%) Network Type: GSM SIM Status: ABSENT,NOT_READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-10-01 Data Encryption State: encrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 355396****** If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [02.14.19 11:22:50] WorkID: 52534048 try to patch cert but still same Chimera Mobile Phone Utility version: 20.22.2159 @ 2019-02-14 Printing phone history Repair IMEI 2/14/2019 9:21:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: unknown Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Oct 29 19:28:09 KST 2018 PDA Version: G570FXXU1CRJ1 [october 2018, rev1] Phone Version: G570FXXU1ARA1 [january 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R28J223R9PX Imei: 35539604978383 Battery Status: 3.73V (7%) Network Type: GSM SIM Status: ABSENT,NOT_READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-10-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. The knox is still valid. Because of the root, the warranty will void. Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image-based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G570F, Region: MEA, Provider: JV, PDA: G570FXXU1CRJ1 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! After the process, the phone can restart once during startup. Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.14.19 11:39:45] WorkID: 52534209 Last edited by TALHAGSM; 02-14-2019 at 11:57. |
The Following User Says Thank You to TALHAGSM For This Useful Post: |
02-14-2019, 14:09 | #369 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Bangladesh
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | Chimera Mobile Phone Utility version: 20.22.2159 @ 2019-02-14 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: CAC Country Code: Central Asia Timezone: Asia/Dhaka Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Thu Sep 28 19:48:56 KST 2017 PDA Version: G570FXXU1BQI9 [september 2017, rev9] Phone Version: G570FXXU1BQI9 [september 2017, rev9] CSC Version: G570FOXE1BQJ2 [october 2017, rev2] Product Code: CAC HIDSw Version: G570FXXU1BQI9/G570FOXE1BQJ2/G570FXXU1BQI9/G570FXXU1BQI9 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58J84DAXNK Imei: 000000000000000 Unique Number: CQ300CF1D6AA664 Connections: AT,MTP Battery Status: 3.93V (48%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-08-01 Data Encryption State: encrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Device disconnected. Try again! Finished at local time: [02.14.19 19:00:56] WorkID: 52550584 |
02-14-2019, 14:15 | #370 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 24,110 | reply Hi, please try to use other usb cable or usb port, device disconnected under the process. Best regards Nicole Quote:
02-14-2019, 15:41 | #371 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | i see in section many peoples giving a false news about imei repair and patched failed, my team already tested on many devices even include G950F all working fine with good network and no problem, so don't create misunderstanding and trouble for good team, and if any person accidentally failed please follow all steps properly then report here, don't directly havocnes and create panic for chimera team |
The Following 2 Users Say Thank You to owais a For This Useful Post: |
02-14-2019, 15:52 | #372 (permalink) |
Freak Poster Join Date: Dec 2012 Location: England
Member: 1854689 Status: Offline Thanks Meter: 15 | G935F Knox 0. 8.0.0 U3. I have installed 4 different firmware and eng modems. But cert patch error? Can someone help me? WorkID: 52561710 Last edited by Yokank; 02-14-2019 at 15:57. |
02-14-2019, 15:58 | #373 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
02-14-2019, 16:00 | #375 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2037770 Status: Offline Thanks Meter: 114 | This is update is just a life saving. I have some question for the @Chimera Tool team. The bug fixing updates made my day and now most of the features are working except some on 8.0 devices. Just to confirm, does the patch certificate process work on 8.0 or 9.0 updates or not? Do you have any work in process to push an update for Qualcomm devices and MTK ? like G532x and others? I'm very glad that you push this update as the community were extremely losing hope in IMEI repair solutions. I was a z3x fan and now I can confirm that Chimera Tool is the most powerful tool I've ever used since years. Thanks. |
The Following User Says Thank You to mr.p3rfekt For This Useful Post: |
