12-03-2019, 07:32 | #856 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | g611f ds repair log Printing phone history Repair IMEI 3.12.2019 06:24:09 Repair IMEI 3.12.2019 06:21:24 Root/Unroot 3.12.2019 06:16:49 Root/Unroot 3.12.2019 06:16:19 Repair IMEI 3.12.2019 06:14:38 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G611F Sales Code: MID Country Code: Iraq Timezone: Europe/Istanbul Android Version: 7.1.1 [NMF26X] [SDK 25] Build Date: Wed Mar 7 19:34:38 KST 2018 PDA Version: G611FXXU1ARC1 [march 2018, rev1] Phone Version: G611FDDU1ARA1 [january 2018, rev1] CSC Version: G611FOJV1ARB2 [february 2018, rev2] Product Code: MID HIDSw Version: G611FXXU1ARC1/G611FOJV1ARB2/G611FDDU1ARA1/G611FXXU1ARC1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58K51GE1KX Imei: 359776019073925 Unique Number: C0000B8B0252335 Connections: AT,MTP Battery Status: 3.80V (41%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-03-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Previous patchcert successfully removed. Checking modem. Checking root. The phone is rooted by: Chimera SU v1.0 Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [12.03.19 09:30:12] WorkID: 81461355 |
12-04-2019, 07:59 | #857 (permalink) |
Junior Member Join Date: Oct 2017 Location: bangladesh
Member: 2765662 Status: Offline Thanks Meter: 3 | sm-n960f Unlocking RMM unlock failed.... chimera tool please help The operation is in progress. Be patient! Do NOT disconnect the phone! It seems, this unlock method is not supported by the phone. Unlock failed. |
12-04-2019, 19:29 | #859 (permalink) | |
Member: 2765662 Status: Offline Thanks Meter: 3 | Quote:
12/4/2019 5:39:19 PM Knoxguard Unlock 12/4/2019 8:14:59 AM Rmm Unlock 12/4/2019 8:13:54 AM Patch Certificate 12/4/2019 8:13:29 AM Patch Certificate 12/4/2019 7:26:49 AM RMM Unlock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Sales Code: XSG Country Code: Bangladesh Timezone: Asia/Dhaka Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 13:16:49 KST 2019 PDA Version: N960FXXU3CSF9 [june 2019, rev9] Phone Version: N960FXXU3ASF1 [june 2019, rev1] CSC Version: N960FOXM3CSF9 [june 2019, rev9] Product Code: BNG HIDSw Version: N960FXXU3CSF9/N960FOXM3CSF9/N960FXXU3ASF1/N960FXXU3CSF9 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: RF8KC0ZAVKJ Imei: 352453548454565 Unique Number: CE10182AAB54A04E3F7E Connections: AT,MTP Battery Status: 3.91V (65%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Unlocking RMM... The operation is in progress. Be patient! Do NOT disconnect the phone! It seems, this unlock method is not supported by the phone. Unlock failed. Finished at local time: [12.04.19 23:42:21] WorkID: 81713245 Sent from my SM-A505F using Tapatalk | |
12-08-2019, 18:41 | #860 (permalink) |
Member: 2765662 Status: Offline Thanks Meter: 3 | At last repair done with chimeratool n960f u3 Security Patch: 2019-06-01 Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-08 Printing phone history Knoxguard Unlock 12/8/2019 5:18:11 PM Knoxguard Unlock 12/8/2019 2:02:53 PM Rmm Unlock 12/8/2019 2:01:46 PM Patch Certificate 12/8/2019 1:51:18 PM Reboot 12/8/2019 1:32:23 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Sales Code: BNG Country Code: Bangladesh Timezone: Asia/Dhaka Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 13:16:49 KST 2019 PDA Version: N960FXXU3CSF9 [june 2019, rev9] Phone Version: N960FXXU3ASF1 [june 2019, rev1] CSC Version: N960FOXM3CSF9 [june 2019, rev9] Product Code: BNG HIDSw Version: N960FXXU3CSF9/N960FOXM3CSF9/N960FXXU3ASF1/N960FXXU3CSF9 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: RF8KC0ZAVKJ Imei: 352453548454565 Unique Number: CE10182AAB54A04E3F7E Connections: AT,MTP Battery Status: 4.14V (88%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 3.14:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.08.19 23:30:51] WorkID: 82173736 |
02-14-2020, 14:12 | #865 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | Samsung Update(14.Feb.2020)- Read Codes Online,Repair IMEI,Patch Cert for new models Dear Chimera Tool Users, Software version: 23.88.0730 Release date: 14. Feb. 2020 What's new? WORLD'S FIRST – Added NEW Read Codes Online, Repair IMEI, Network Repair/Patch Cert Methods for Exynos Models : Modem BIT: ALL
Read Codes Online, Repair IMEI, Network Repair/Patch Cert, Firmware Flash/Compatibility, Backup/Restore added for New Exynos Models: Modem BIT: ALL
* Procedures work only with Magisk based roots. Visit our Webshop: https://chimeratool.com/shop Like us on Facebook: https://www.facebook.com/chimeratool Read our Help & Documentation: https://chimeratool.com/docs Get Support: https://chimeratool.com/contact GsmEasy Distributor: http://www.imei.us GsmServer Distributor: http://www.gsmserver.com |
The Following 3 Users Say Thank You to Chimera Tool For This Useful Post: |
02-14-2020, 15:50 | #868 (permalink) |
Banned Join Date: Mar 2019 Location: Gsm-Boss Age: 46
Member: 2902804 Status: Offline Sonork: 100.1660513 Thanks Meter: 928 | amazing update as usual Repair IMEI + Patch Cert for new models =================== WORLD'S FIRST – Added NEW Read Codes Online Repair IMEI Network Repair/Patch Cert Methods for Exynos Models BIT: ALL, KNOX: ANY, ROOT: YES Samsung Galaxy J2 Core 2018 SM-J260A, SM-J260AZ, SM-J260M, SM-J260Y, SM-J260F, SM-J260G, SM-J260T1 Samsung Galaxy J4 SM-J400F, SM-J400M, SM-J400G Samsung Galaxy J3 2017 SM-J330F, SM-J330FN, SM-J330G, SM-J330L, SM-J330N Samsung Galaxy J3 2018 SM-J336AZ, SM-J337A, SM-J337U, SM-J337T, SM-J337W Samsung Galaxy J3 Emerge SM-J326AZ, SM-J327A, SM-J327U, SM-J327T, SM-J327T1, SM-J327W Samsung Galaxy J5 Prime SM-G570F, SM-G570M, SM-G570Y Samsung Galaxy Xcover 4 2017 SM-G390F, SM-G390Y, SM-G390W ---------------- Read Codes Repair IMEI Network Repair/Patch Firmware Flash/Compatibility, Backup/Restore added for New Exynos Models BIT: ALL, KNOX: ANY, ROOT: NO Samsung Galaxy A51 2019 SM-A515F Samsung Galaxy Note 10 Lite SM-N770F Samsung Galaxy XCover Pro SM-G715FN Samsung Galaxy Xcover FieldPro SM-G889F Samsung Galaxy M31 SM-M315F Samsung Galaxy A30 SM-A3051 Procedures work only with Magisk based roots |
The Following User Says Thank You to Gsm-Boss. For This Useful Post: |
02-14-2020, 17:23 | #870 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | will Enjoy it, if there is a good update in Huawei.... world 1st,as always, we know chimera can do it... I hope there is some good news in Huawei too, soon.......... |
