Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 01-24-2024, 14:16   #1876 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,772
Samsung KnoxGuard MDM-like locks can be removed
New features and improvements
MDM Remove procedure has arrived for Samsung Exynos devices! KnoxConfigure, KnoxMobileEnrollment/BulkEnrollment and KnoxFirmwareManagement locks can be removed. The procedure works in EUB mode and the changes are permanent, the lock does not come back, even after factory reset, updates or firmware flash. It works on all Samsung security updates, up to the latest. The supported devices are:
  • Samsung Galaxy A04s (SM-A047F, SM-A047M)
  • Samsung Galaxy A12 (SM-A127F, SM-A127M)
  • Samsung Galaxy M12 (SM-M127F, SM-M127G, SM-M127N)
  • Samsung Galaxy F12 (SM-F127G)
  • Samsung Galaxy A13 (SM-A135F, SM-A135M, SM-A135N, SM-A135U, SM-A135U1)
  • Samsung Galaxy M13 (SM-M135F, SM-M135FU, SM-M135M)
  • Samsung Galaxy F13 (SM-E135F)
  • Samsung Galaxy A14 (SM-A145F, SM-A145FB, SM-A145M, SM-A145MB)
  • Samsung Galaxy A21s (SM-A217F, SM-A217M, SM-A217N)
  • Samsung Galaxy XCover 5 (SM-G525F, SM-G525N)
  • Samsung Galaxy A25 5G (SM-A256B, SM-A256E)
  • Samsung Galaxy A33 5G (SM-A336B, SM-A336E, SM-A336M, SM-A336N, SM-A3360)
  • Samsung Galaxy A53 5G (SM-A536B, SM-A536E, SM-A536N, SM-A536V, SM-A536W, SM-A536U, SM-A536U1, SM-A5360, SM-S536DL, SC-53C, SCG15)
  • Samsung Galaxy M33 5G (SM-M336B, SM-M336BU, SM-M336K)
  • Samsung Galaxy M34 5G (SM-M346B, SM-M346B1, SM-M346B2)
  • Samsung Galaxy F34 5G (SM-E346B)
  • Samsung Galaxy A14 5G (SM-A146B, SM-A146M)
  • Samsung Galaxy F14 5G (SM-E146B)
  • Samsung Galaxy M14 5G (SM-M146B)
  • Samsung Galaxy A54 5G (SM-A546B, SM-A546E, SM-A546S, SM-A546U, SM-A546U1, SM-A546V, SM-A546W, SM-A5460, SM-S546VL)
  • Samsung Galaxy M54 5G (SM-M546B)
  • Samsung Galaxy F54 5G (SM-E546B)
  • Samsung Galaxy Tab S9 FE 5G (SM-X516B, SM-X516C, SM-X518U)
  • Samsung Galaxy Tab S9 FE Plus 5G (SM-X616B, SM-X616C)
  • Samsung Galaxy A51 5G (SM-A516B, SM-A516N, SM-A516U, SM-A516U1, SM-A5160)
  • Samsung Galaxy A71 5G (SM-A716B, SM-A716S, SM-A7160)
  • Samsung Galaxy S20 (SM-G980F)
  • Samsung Galaxy S20 Plus (SM-G985F)
  • Samsung Galaxy S20 5G (SM-G981B)
  • Samsung Galaxy S20 Plus 5G (SM-G986B)
  • Samsung Galaxy S20 Ultra 5G (SM-G988B)
  • Samsung Galaxy Note 20 (SM-N980F)
  • Samsung Galaxy Note 20 Ultra (SM-N985F)
  • Samsung Galaxy Note 20 5G (SM-N981B)
  • Samsung Galaxy Note 20 Ultra 5G (SM-N986B)
  • Samsung Galaxy S20 FE (SM-G780F)
  • Samsung Galaxy S21 FE 5G (SM-G990E)
  • Samsung Galaxy S21 5G (SM-G991B, SM-G991N)
  • Samsung Galaxy S21 Plus 5G (SM-G996B, SM-G996N)
  • Samsung Galaxy S21 Ultra 5G (SM-G998B, SM-G998N)
Important note: If you still find the device locked after MDM Remove, please run a Factory reset manually for the changes to take effect. If you get an "MDM not detected" error, it is likely that you have a different lock on the device, such as Find My Mobile, SmartThings Find, Lost mode or any other. In this case, try other procedures. Knoxguard itself cannot be removed with this procedure.
More Exynos features are arriving soon, stay tuned for the upcoming ChimeraTool updates!
Software version: 38.28.1232
Release date: 24 january 2024
The Following 5 Users Say Thank You to Chimera Tool For This Useful Post:
Old 01-24-2024, 18:27   #1877 (permalink)
Member: 1724300
Thanks Meter: 42
BOOMMMMMM
wow
tnx
The Following User Says Thank You to sajad0789 For This Useful Post:
Old 01-24-2024, 20:12   #1878 (permalink)
Member: 1678953
Thanks Meter: 67
Bravo Chimera Tool Team, really grate job.
The Following User Says Thank You to KingRool For This Useful Post:
Old 01-24-2024, 20:40   #1879 (permalink)
Crazy Poster
Member: 3041178
Thanks Meter: 12
Chimera is rock yaar
The Following User Says Thank You to khalidsuper12 For This Useful Post:
Old 01-25-2024, 08:01   #1880 (permalink)
obama2's Avatar
Member: 952862
Thanks Meter: 48
chimera u said all binary supported but a047f u5 and a145f u4 all testpoints are disabled did u think of it?
Old 01-25-2024, 09:12   #1881 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
After Updating MTK Devices not connects ......................
Chimera Mobile Phone Utility version: 38.28.1232 @ 2024-01-25
Autodetect features
Change to bootrom mode
Please reinstall MTK drivers!
Finished at local time: [01.25.24 12:08:08]
WorkID: 256263588
Reinstalled drivers still same.............
Old 01-25-2024, 13:14   #1882 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 505
Wow this is doPe so this mean kg service can't relock the device after connect to internet right?
Best Regards | Yoba
Old 01-25-2024, 14:07   #1883 (permalink)
Member: 1787203
Dear User,
After the MDM procedure the phone should not relock, after reset or firmware update based on our tests.
Best Regards,
ChimeraTeam
Best Regards | Yoba
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 01-25-2024, 15:18   #1884 (permalink)
Member: 2708486
Remove MDM
Failed to remove MDM
Finished at local time: [01.25.24 15:16:08]
WorkID: 256325580
Samsung A127f U9
Old 01-25-2024, 16:14   #1885 (permalink)
Member: 1787203
Dear User,
You phone most likely has an other lock like KG, and it is not supported for MDM Removal.
Best Regards,
ChimeraTeam
Originally Posted by psinochal View Post
Remove MDM
WorkID: 256325580
Samsung A127f U9
Old 01-25-2024, 16:19   #1886 (permalink)
Member: 2708486
Dear User,
Best Regards,
ChimeraTeam
yes, its kg locked. Is it any way to unlock it?
Old 01-25-2024, 17:27   #1887 (permalink)
obama2's Avatar
Member: 952862
Thanks Meter: 48
Dear User,
Best Regards,
ChimeraTeam
Can you explain why a047f u5 and a145f u4 test points are disabled?
Old 01-26-2024, 09:32   #1888 (permalink)
Member: 1787203
Dear User,
You can do a KG removal and then unlock the bootloader and flash a KG patched rom to the phone.
Best Regards,
ChimeraTeam
Old 01-26-2024, 15:03   #1889 (permalink)
Member: 1291626
hi,
this tools can unlock samsung finance plus on xcover 5
Old 02-02-2024, 16:18   #1890 (permalink)
Member: 612330
Thanks Meter: 35
You wrote ""The procedure works in EUB mode and the changes are permanent "
But after connect to WiFi it comes again (tested A516N) or flash ( tested A047F) ?
Solution just change KG state for offline mode?
Page generated in 0.11858 seconds with 9 queries
