Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-15-2020, 19:44   #181 (permalink)
Member: 220595
Thanks Meter: 354
Originally Posted by Chimera Tool View Post
Software version: 24.79.1106
Release date: 15 May 2020
Chimera Team keep up the hard work, here is our biweekly changelog and some other information.
New features and improvements:
  • Generic: Better GZIP handling
  • Generic: Improved worldwide server caching for faster response & downloads
  • Oppo: New XML format is now supported
  • LG MTK: New warning for paid procedures (before start)
  • Samsung: Improved Read Codes for older Qualcomm models (Galaxy S8 /SM-G950x/G955x, Galaxy Note8 /SM-N950x, etc.)
  • Samsung: Improved T-Mobile unlock for Exynos models (Galaxy A6 /SM-A600T-T1, Galaxy J2 /SM-J260T1, etc.)
You can test now:
  • LG: Added Network Factory Reset, FRP and IMEI Repair for many LG-Qualcomm devices. Itís out as BETA, we need you to use it and test it so we can create a detailed model list. You will be warned if the procedure is running in BETA mode.
May I test network factory reset on sprint Stylo 5?
Enviado desde mi SM-G975U1 mediante Tapatalk
The Following User Says Thank You to yurais For This Useful Post:
Old 05-15-2020, 20:14   #182 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
Can we use OFP extracted Firmware for factory reset/frp or other operation?
Old 05-15-2020, 20:33   #183 (permalink)
Member: 1865210
Thanks Meter: 2
Please add Samsung a10s frp and kg lock state removal
Old 05-15-2020, 20:36   #184 (permalink)
Member: 1865210
Thanks Meter: 2
Frp and kg lock removal
Please add Samsung a107f frp and kg lock removal.
Old 05-15-2020, 20:44   #185 (permalink)
Member: 220595
Thanks Meter: 354
Plus a107 imei repair
Old 05-15-2020, 21:06   #186 (permalink)
Member: 220595
Thanks Meter: 354
Lg Q710CS is detected as an unknown device.
What model should I select to test the new network factory reset feature?
Old 05-15-2020, 21:33   #187 (permalink)
Member: 1679218
Thanks Meter: 50
Thanks for your update..
Old 05-15-2020, 21:57   #188 (permalink)
Member: 1484663
Thanks Meter: 344
Hi, thanx for your effort. Please add a list of possible new supported LG Qualcomm devices.
Old 05-15-2020, 22:00   #189 (permalink)
Member: 220595
Thanks Meter: 354
I tried using model x300 and it resulted in protocol error .
Look at the picture the jobs ID, and get what you need ...
Cya
Old 05-16-2020, 01:46   #190 (permalink)
Member: 249497
Thanks Meter: 180
On LG new update network reset = network unlock ?
if its true can you provide hint about LG G8S from At&T
my yearly activation is about to expire ill renew if LG can be unlocked
Old 05-16-2020, 04:27   #191 (permalink)
Member: 220595
Thanks Meter: 354
Yes, it is some sort of network unlock.
It resets simlock area to values as it was firstly set by LG
Old 05-16-2020, 06:17   #192 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Good Tool and good update...
Old 05-16-2020, 07:19   #193 (permalink)
Member: 949240
Thanks Meter: 83
Error! Couldn't find appropriate Qualcomm programmer!
The procedure has been canceled.
The phone is in an invalid state, please reconnect the USB cable and reboot it manually!
WorkID: 95399463
The Following User Says Thank You to deepakgilda For This Useful Post:
Old 05-16-2020, 14:10   #194 (permalink)
worldlinkmobil's Avatar
Member: 1275418
Thanks Meter: 432
hi chimera team can i flash vivo v17 with chimare.
Old 05-16-2020, 16:07   #195 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 928
nice update
Page generated in 0.15469 seconds with 9 queries
