04-22-2024, 13:48 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | N986B U10 imei repair and advice which firmware can works Code: Chimera Mobile Phone Utility version: 39.14.1236 @ 2024-04-22 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N986B Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Europe/Istanbul Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Tue Jan 23 14:10:35 KST 2024 PDA Version: N986BXXSAHXB1 [february 2024, rev1] Phone Version: N986BXXSAHXB1 [february 2024, rev1] CSC Version: N986BOXMAHXB2 [february 2024, rev2] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Imei: 354255812593467 Battery Status: 3.79V (66%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2024-02-01 Em Did: 200BF78EB8EC6011 Repair imei... Servicing phone. Be patient! Do NOT disconnect the phone! Restarting phone Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Firmware not supported, please attempt to downgrade if possible. Finished at local time: [04.22.24 15:44:09] WorkID: 272179297 |
04-22-2024, 14:57 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | Dear User, We do not have a solution for this problem unfortunately. IMEI Repair is not supported yet on this binary version. Best Regards, ChimeraTeam Quote:
04-22-2024, 15:31 | #3 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | thank you for fast answer but as i said some one already did this (but i am not sure how )bit can you double check |
04-24-2024, 12:58 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | Dear User, The Remove Anti-rollback Lock procedure is used in different situations, and not applicable for repairing IMEI with higher binaries. As soon as we have a solution to the new security patches, we are adding them. Best Regards, ChimeraTeam |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-24-2024, 15:44 | #7 (permalink) | |
Crazy Poster Join Date: May 2018
Member: 2839691 Status: Offline Thanks Meter: 15 | Quote:
If you run the Antirollback procedure on a lower revision phone successfully, then update the phone to newest firmware, you would be able to downgrade the modem and run all operations. A phone has to run Antirollback operation just once, successfully, then modem should always be downgradable. If the phone is on newest revision, and has not previously run the Antirollback procedure, you would have to wait for a new update/exploit. | |
04-25-2024, 19:06 | #8 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | I am sure Chimera will do it again and support all new Binary |
The Following 2 Users Say Thank You to Fast Unlocker For This Useful Post: |
