01-22-2024, 13:00 | #5 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,028 | Dear User, We have added this model, please check it now. In ADB you will need to root the phone (as this is an USA model the root might be tricky). In EUB mode, you will need to Testpoint the device. If your phone is T-mobile or Verizon, we won't be able to unlock it. Best Regards, ChimeraTeam |
01-24-2024, 14:16 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,028 | Samsung KnoxGuard MDM-like locks can be removed Samsung KnoxGuard MDM-like locks can be removed New features and improvements MDM Remove procedure has arrived for Samsung Exynos devices! KnoxConfigure, KnoxMobileEnrollment/BulkEnrollment and KnoxFirmwareManagement locks can be removed. The procedure works in EUB mode and the changes are permanent, the lock does not come back, even after factory reset, updates or firmware flash. It works on all Samsung security updates, up to the latest. The supported devices are:
Important note: If you still find the device locked after MDM Remove, please run a Factory reset manually for the changes to take effect. If you get an "MDM not detected" error, it is likely that you have a different lock on the device, such as Find My Mobile, SmartThings Find, Lost mode or any other. In this case, try other procedures. Knoxguard itself cannot be removed with this procedure. More Exynos features are arriving soon, stay tuned for the upcoming ChimeraTool updates! Software version: 38.28.1232 Release date: 24 january 2024 |
The Following 5 Users Say Thank You to Chimera Tool For This Useful Post: |
01-24-2024, 18:27 | #7 (permalink) | |
Freak Poster Join Date: Feb 2012 Location: iran
Member: 1724300 Status: Offline Thanks Meter: 42 | Quote:
wow tnx | |
The Following User Says Thank You to sajad0789 For This Useful Post: |
01-25-2024, 13:14 | #8 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 486 | Quote:
Best Regards | Yoba | |
02-02-2024, 16:18 | #13 (permalink) | |
Freak Poster Join Date: Oct 2007
Member: 612330 Status: Offline Thanks Meter: 35 | Quote:
You wrote ""The procedure works in EUB mode and the changes are permanent " But after connect to WiFi it comes again (tested A516N) or flash ( tested A047F) ? Solution just change KG state for offline mode? | |
02-02-2024, 16:34 | #14 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,028 | Dear User, It is permanent if your phone has MDM lock, if your phone has KG lock, then this procedure won't be the right one for it. If your phone has KG lock, you can permanently disable it only by doing a KG Remove and BL unlock then with a patched firmware. Best Regards, ChimeraTeam |
