11-04-2021, 10:01 | #16 (permalink) |
No Life Poster Join Date: Apr 2021 Location: GSM AFRICA TEAM (SA)
Member: 2986985 Status: Offline Thanks Meter: 163 | tecno ke5 frp remove done by Chimera Tool Code: Chimera Mobile Phone Utility version: 30.09.0754 @ 2021-11-04 Remove FRP lock Removing factory reset protection... Waiting for the phone to restart... Finished at local time: [11.04.21 10:58:49] WorkID: 156854415 |
The Following User Says Thank You to Gsm Africa Team For This Useful Post: |
11-04-2021, 21:40 | #18 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | still not work id remove y7p Chimera Mobile Phone Utility version: 30.17.1048 @ 2021-11-04 Printing phone history Load Factory Fastboot 2021-11-04 20:33 Huawei Id & Frp Remove 2021-11-04 20:25 FRP Remove 2021-10-29 17:06 Load Factory Fastboot 2021-10-29 17:04 Removing factory reset protection... Collecting information about the device... Removing factory reset protection lock... It did not work. Removing factory reset protection lock... It did not work. Checking if factory challenge needed... Already unlocked. Wiping device... Finished at local time: [11.04.21 21:33:51] WorkID: 156945448 |
11-05-2021, 10:37 | #19 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,752 | reply Dear User, You posted an FRP RESET work, which was reported back as a successfully done job. Can you please run the ID remove? Best regards Sab Chimera team Quote:
11-07-2021, 17:01 | #20 (permalink) |
Member: 1350724 Status: Offline Thanks Meter: 188 | Chimera Mobile Phone Utility version: 30.17.1048 @ 2021-11-07 Removing Huawei account Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [11.07.21 16:57:34] WorkID: 157276294 stil not work |
11-08-2021, 11:08 | #21 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,752 | reply Dear User, Thank you for the feedback. We will check the logs for sure. however, we do not see the problem source yet. We will inform you about the news, of course, if we will need more information, we will contact you! Best regards Sab Chimera Tem Quote:
11-12-2021, 20:55 | #26 (permalink) | |
Member: 1350724 Status: Offline Thanks Meter: 188 | Quote:
IT IS STILL NOT WORK Chimera Mobile Phone Utility version: 30.17.1048 @ 2021-11-12 Removing Huawei account Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [11.12.21 20:36:01] WorkID: 157947962 | |
11-15-2021, 11:38 | #27 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,752 | reply Dear User, Thank you for the feedback. We are still working on the Service, so more fixes will come. The main issue comes from the Firwmare security patch, so at least we know that. Hopefully, we can update it ASAP. Best regards Sab Chimera team Quote:
11-25-2021, 14:32 | #28 (permalink) |
Member: 1350724 Status: Offline Thanks Meter: 188 | hi after downgrade it is still not posible to bypass huawei id ART-L29 +ART-L29N 10.1.0.112(C185E2R3P) Chimera Mobile Phone Utility version: 30.31.1318 @ 2021-11-25 Removing Huawei account Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [11.25.21 14:26:34] WorkID: 159547285 |
11-26-2021, 11:16 | #29 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,752 | reply Hello, We checked the work, it was reported as successfully done. The factory reset was done automatically? Quote:
12-09-2021, 11:57 | #30 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 713641 Status: Offline Thanks Meter: 5 | y6p id not working hy same problem not working Removing Huawei-ID Protection from the device... Unlocking bootloader... Removing factory reset protection... Removing Huawei-ID Protection from the device... Factory reset the device... Waiting for the phone to restart... Please reboot your phone by long-pressing the power button! Finished at local time: [12.08.21 17:11:57] WorkID: 161274703 what is the solution for y6p huawei id |
