08-14-2022, 10:16 | #1426 (permalink) |
Freak Poster Join Date: Mar 2018
Member: 2824019 Status: Offline Thanks Meter: 83 | Samsung A325f Not going to brom Without Test Point: Chimera can automatically change to bootrom mode (soft brick) for most Samsung MTK models (if possible)! We always focused on easy and user friendly solutions and this update means that you can service a lot more devices with Chimera just using a cable, without hardware disassemble. [[COLOR="Cyan"Samsung A325f Not going to brom also i try tp not connecting to chimera try to connect with volume up and down Not Connecting [/COLOR] |
08-15-2022, 09:29 | #1429 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,203 | reply Dear User, The mentioned devices are not supported for the IMEI REPAIR services. Here you can check which methods are actually added to the asked model types: https://chimeratool.com/en/models Best regards Sab Chimera team |
08-15-2022, 09:31 | #1430 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,203 | reply Dear User, Please let us know your username so we can check the Logs from our end. Best regards Sab Chimera team Quote:
08-22-2022, 15:57 | #1437 (permalink) | |
Insane Poster Join Date: Apr 2014 Location: Brasil -RJ Age: 42
Member: 2160165 Status: Offline Thanks Meter: 7 | Quote:
vivo v21 error, not work? | |
08-23-2022, 08:58 | #1438 (permalink) |
Junior Member Join Date: Dec 2010 Location: Tunisie
Member: 1476214 Status: Offline Thanks Meter: 0 | Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325F Carrier ID: EUX Sales Code: THL Country Code: THAILAND Timezone: Africa/Tunis Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Mon Oct 18 13:18:40 KST 2021 PDA Version: A325FXXU2AUJ4 [october 2021, rev4] Phone Version: A325FXXU2AUJ4 [october 2021, rev4] CSC Version: A325FOLM2AUJ3 [october 2021, rev3] Board Platform: MT6768 Modem Platform: MT6765 Imei: *************** Network Type: GSM SIM Status: ABSENT,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 2008655BFD114311 Preparing... Previously installed patchcert detected. Previously installed patchcert successfully removed. Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.22.22 14:33:14] WorkID: 192440550 |
08-23-2022, 08:59 | #1439 (permalink) | |
Member: 1476214 Status: Offline Thanks Meter: 0 | Quote:
Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325F Carrier ID: EUX Sales Code: THL Country Code: THAILAND Timezone: Africa/Tunis Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Mon Oct 18 13:18:40 KST 2021 PDA Version: A325FXXU2AUJ4 [october 2021, rev4] Phone Version: A325FXXU2AUJ4 [october 2021, rev4] CSC Version: A325FOLM2AUJ3 [october 2021, rev3] Board Platform: MT6768 Modem Platform: MT6765 Imei: *************** Network Type: GSM SIM Status: ABSENT,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 2008655BFD114311 Preparing... Previously installed patchcert detected. Previously installed patchcert successfully removed. Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.22.22 14:33:14] WorkID: 192440550 | |
