04-30-2024, 12:39 | #1 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,028 | ⭐️30/04/2024⭐️New Exynos 9810/9820/9825 - 28 models - No Root, Any Bit/Version/Knox The game-changing update continues! This time, we're proudly announcing support for Exynos 9810, Exynos 9820 and Exynos 9825. Go ahead and try it! We promise you won’t regret it. This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device. The following devices are supported:
Available procedures: Restore / Store Backup, Unlock / Relock Bootloader, CSC Change, Change Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (**) For more detailed information, please visit our Supported models page. If you'd like to see this working check out our videos:
Mark your calendars! More to come on the 2nd of May... Credit costs reduced For Samsung models Read Codes procedure prices went down! *: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here and our Test Point Database to learn more. **:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available. Software version: 39.25.1235 Release date: 30 april 2024 Visit our Webshop: https://chimeratool.com/shop Join our Telegram: https://t.me/chimeratool_offical Like us on Facebook: https://www.facebook.com/chimeratool Read our Help & Documentation: https://chimeratool.com/docs Get Support: https://chimeratool.com/contact GsmEasy Distributor: http://www.imei.us GsmServer Distributor: http://www.gsmserver.com |
The Following 13 Users Say Thank You to Chimera Tool For This Useful Post: |
04-30-2024, 13:51 | #5 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,028 | Dear User, Can you tell us more about this network lock? Does the phone ask for codes? Or is it something special? If you can share more information about this type of network lock, so that we can look into it. Regards, ChimeraTeam |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-30-2024, 16:45 | #7 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 486 | Chimera always rocking good keep it up team please add bypass/remove mdm knox guard procedure using adb interface Best Regards | Yoba |
The Following User Says Thank You to eyobaaa For This Useful Post: |
05-02-2024, 13:40 | #11 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,028 | Dear User, Can you elaborate please? We would like to improve Chimera, but first we need to know your exact issue. Which phones have you tried to do? Best Regards, ChimeraTeam |
05-03-2024, 06:26 | #13 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Negros, Philippines
Member: 525940 Status: Offline Thanks Meter: 213 | Quote:
it not ask for network unlock it display use only with SMART / TNT simcard | |
