Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-26-2021, 10:48   #706 (permalink)
Member: 2973928
Thanks Meter: 245
Team we want samsung all model 2021 new security & patch repair thnx...
Old 03-26-2021, 12:55   #707 (permalink)
Registered User
Member: 731353
Thanks Meter: 251
add samsung a260f MDMplease,,,,,,written on your site but not supported all Bits
Old 03-26-2021, 13:01   #708 (permalink)
Member: 2698409
Thanks Meter: 244
Please add Huawei Mate 40 pro.
The Following User Says Thank You to oscar.freire For This Useful Post:
Old 03-26-2021, 13:02   #709 (permalink)
lsrfrz's Avatar
Member: 931565
Sonork: 100.1626372
Thanks Meter: 45
Good update thanks chimera team
keep it up
The Following User Says Thank You to lsrfrz For This Useful Post:
Old 03-26-2021, 13:31   #710 (permalink)
Member: 1677653
Thanks Meter: 2,744
I need working root method for Samsung A217F, binary 2.
Thanks in advance
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 03-26-2021, 14:07   #711 (permalink)
Member: 2838160
Thanks Meter: 8
job not done credit deducted
Good great team please job failed but deduct my credit pls help me out
Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-26
Read codes started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A515F
Carrier ID: EUX
Country Code: UK
Timezone: Africa/Lagos
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Mon Oct 5 19:16:03 KST 2020
PDA Version: A515FXXU4CTJ1 [october 2020, rev1]
Phone Version: A515FXXU4CTJ1 [october 2020, rev1]
CSC Version: A515FOXM4CTJ1 [october 2020, rev1]
Board Platform: UNIVERSAL9611
Modem Platform: SHANNON337
Imei: 353194566961839
Imei2: 354558596961838
Network Type: GSM
SIM Status: ABSENT,LOADED
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2020-10-01
Reading codes online...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Read codes failed.
Finished at local time: [03.26.21 20:50:19]
WorkID: 129178447
Old 03-26-2021, 14:13   #712 (permalink)
FREDDIE GTY's Avatar
Member: 1340870
Sonork: 1611357
Thanks Meter: 143
is samsung a716u 5g tmobile usa supported for
permanent network unlock
Old 03-26-2021, 15:23   #713 (permalink)
Member: 1718952
Thanks Meter: 37
J530 u7 pach ceret???
Old 03-26-2021, 15:47   #714 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 22,863
reply
Hi there,
Which model variant exactly? The Samsung Galaxy J5 does have 9 model variants, that we can support.
https://chimeratool.com/en/models#q=J530
Best regards
Sab
Chimera team
Old 03-26-2021, 15:48   #715 (permalink)
Member: 1787203
reply
Hi there,
Although the mentioned phone - a716u- is supported by the Chimera Tool:
https://chimeratool.com/en/models#q=a716u
The unlock process is not added for the T-mobile version.
Best regards
Sab
Chimera Team
Old 03-26-2021, 16:22   #716 (permalink)
Member: 2711874
Sonork: 100.650600
Thanks Meter: 462
always good update team
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 03-27-2021, 07:29   #717 (permalink)
Member: 2975718
today I tried to patch cert in model sm-g977n OS11 bit 4 and it had boot loop, then I try in os10 with autoroot and Get this error message:
ODIN MODE (AVB Fail)
recovery: Error validating footer. (0)
recovery: Error verifiying vbmeta image: invalid vbmeta header (6)
CUSTOM RECOVERY.
OS11 with autoroot get it too. please help me with it.
Old 03-27-2021, 07:40   #718 (permalink)
Member: 2975718
here my work id:
Model: SM-G977N
Carrier ID: LUC
Sales Code: LUC
Country Code: KOREA
Timezone: Asia/Ho_Chi_Minh
Android Version: 11 [RP1A.200720.012] [SDK 30]
Build Date: Thu Feb 18 14:58:50 KST 2021
PDA Version: G977NKSU4FUBD [february 2021, revD]
Phone Version: G977NKOU4FUBD [february 2021, revD]
CSC Version: G977NOKR4FUBD [february 2021, revD]
Product Code: LUC
HIDSw Version: G977NKSU4FUBD/G977NOKR4FUBD/G977NKOU4FUBD/G977NKSU4FUBD
Board Platform: UNIVERSAL9820
Modem Platform: SHANNON50005100
Serial Number: R3CM40N67CA
Imei: 355401101053719
Connections: AT,MTP
Battery Status: 4.13V (83%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-03-01
Preparing...
Checking root access.
The phone is rooted by: 22.0:MAGISKSU
Reading data...
Patching certificate...
The phone must be started in recovery mode to be rooted!
To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power].
Without root the patchcert will not work!
Restarting phone in recovery mode...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Successfully finished.
Finished at local time: [03.27.21 13:21:29]
WorkID: 129250758
The Following User Says Thank You to kunzzz For This Useful Post:
Old 03-27-2021, 15:28   #719 (permalink)
Member: 2596452
Thanks Meter: 4
add g570m u9 imei fix please
The Following User Says Thank You to Norbert284 For This Useful Post:
Old 03-28-2021, 12:46   #720 (permalink)
Member: 1763949
Sonork: 100.1639086
Thanks Meter: 5
oppo a5 2020 supported for flashing ?
Page generated in 0.19705 seconds with 9 queries
