07-27-2020, 10:17 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: USA
Member: 2562737 Status: Offline Thanks Meter: 75 | [A10][A105F] Samsung Galaxy A10 Android 10 IMEI repair DONE! IMEI repair: Code: Chimera Mobile Phone Utility version: 25.46.0928 @ 2020-07-22 Printing phone history Get Info 7/22/2020 10:49:12 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: CAU Country Code: Georgia Timezone: Asia/Baku Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Apr 23 21:22:59 KST 2020 PDA Version: A105FDDU3BTD4 [april 2020, rev4] Phone Version: A105FXXU3BTD1 [april 2020, rev1] CSC Version: A105FOXM3BTE1 [may 2020, rev1] Product Code: CAU HIDSw Version: A105FDDU3BTD4/A105FOXM3BTE1/A105FXXU3BTD1/A105FDDU3BTD4 Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RZ8M80WWA7R Imei: 359************** Unique Number: CBJ00D199BCEE76 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-05-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying on port SAMSUNG Mobile USB Serial Port (COM25) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM25) Processing. Be patient! Do NOT disconnect the phone! Current imei: 359************19 Repaired imei: 359***********75 Current imei2: 359***********17 Repaired imei2: 359**********73 Successfully finished. Finished at local time: [07.22.20 14:53:47] WorkID: 101513302 Code: Chimera Mobile Phone Utility version: 25.46.0928 @ 2020-07-22 Printing phone history SW Change 7/22/2020 1:31:50 PM Patch Certificate 7/22/2020 12:54:33 PM Reboot 7/22/2020 12:24:28 PM Patch Certificate 7/22/2020 12:17:47 PM Patch Certificate 7/22/2020 12:16:15 PM Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: CAU Country Code: Georgia Timezone: Asia/Baku Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Dec 18 20:40:30 KST 2019 PDA Version: A105FPUU3ASL3 [december 2019, rev3] Phone Version: A105FXXU3ATA1 [january 2020, rev1] CSC Version: A105FOXM3BTE1 [may 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8M80WWA7R Battery Status: 4.33V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-12-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.22.20 18:46:49] WorkID: 101540205 |
The Following 2 Users Say Thank You to farizazizov For This Useful Post: |
04-27-2021, 13:50 | #4 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | done pda version A105FDDS6BUB1 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Carrier ID: KSA Sales Code: INS Country Code: India Timezone: Asia/Dhaka Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed Feb 3 16:57:39 KST 2021 PDA Version: A105FDDS6BUB1 [february 2021, rev1] Phone Version: A105FDDS6BUB1 [february 2021, rev1] CSC Version: A105FODM6BUB1 [february 2021, rev1] Product Code: INS HIDSw Version: A105FDDS6BUB1/A105FODM6BUB1/A105FDDS6BUB1/A105FDDS6BUB1 Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RF8M70P98NL Imei: 867755776656564 Imei2: 867755776656556 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-02-01 Em Did: 6636edccaf6c Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 867755776656564 Repaired imei: 3************** Current imei2: 867755776656556 Repaired imei2: 3*************** Successfully finished. Finished at local time: [04.27.21 18:42:34] WorkID: 132576778 Last edited by pintu_das; 04-27-2021 at 13:56. |
The Following User Says Thank You to pintu_das For This Useful Post: |
04-27-2021, 14:24 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, Thank you for the feedback! Good work from you! Best regards Sab Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
