01-29-2023, 06:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | A102N U3 *#0808# not working to repair IMEI WBR |
01-30-2023, 07:18 | #3 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
Thanks for your replying I have enable USB debugging from Developer Options Chimera tool ask to dail *#0808# and enable diag port DM+Modem+ADB but the code *#0808# doesnt work in this phone . WBR | |
02-02-2023, 07:08 | #6 (permalink) | |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | Quote:
Flash this A102NKOU3BTH1,do root. Repair method 2020 September Patch method 2020 October. Also for Korean models diag enable codes: 319712358 774632 0821 996412 This codes 100 percent workable because in my country every third hippy goes to Korean republic for work. | |
The Following 3 Users Say Thank You to Dilmurod1999 For This Useful Post: |
02-02-2023, 13:56 | #7 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Thank You everyone for replying I repaired it by flashing with This Patched firmware without patching IMEI : https://drive.google.com/file/d/169h...ew?usp=sharing WBR |
The Following User Says Thank You to NKhan_Gsm For This Useful Post: |
05-08-2023, 04:12 | #8 (permalink) | ||
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Samsung A102N convert Global and Auto Patch Quote:
I tried many different types of firmwares like as below. A102NKOU1ATA1 A102NKOU2ATA2 A102NKOU2BTE4 A102NKOU3BTH1 A102NKOU3BTL1 A102NKOU3BUA1 None of them worked but below message always stood in front of me. Unable to patch certificate. Thanks to Quote:
The Following 2 Users Say Thank You to hafiz4saqib For This Useful Post: |
05-08-2023, 07:05 | #9 (permalink) | |
And l have some questions to you: Why your screenshot partial?Why you used newer Magisk for old firmware? There is no point of using dirty (patch backup) autopatch. Magisk 23-24.3 is tested and works well for that firmware version. Always first of all read instruction,logs,documentation!!! | |
05-08-2023, 11:56 | #10 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,747 | Dear User, Can you try to do a factory reset on the phone, then flash it with A102FXXU3BTH1? Then root it with MAGISK (V20.4-22) then run the Patch cert? Thank you, ChimeraTeam |
