06-08-2019, 21:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2499218 Status: Offline Thanks Meter: 44 | Repair IMEI Patch Certificate a520f u9 Succeeded. Printing phone history Patch Certificate 6/8/2019 8:22:47 PM Patch Certificate 6/8/2019 8:20:47 PM Repair IMEI 6/8/2019 8:18:12 PM Patch Certificate 5/28/2019 3:57:34 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: THR Country Code: IRAN Timezone: Asia/Tehran Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Apr 9 16:08:23 KST 2019 PDA Version: A520FXXS9CSD2 [april 2019, rev2] Phone Version: A520FXXU9CSD4 [april 2019, rev4] CSC Version: A520FOJV9CSD1 [april 2019, rev1] Product Code: THR HIDSw Version: A520FXXS9CSD2/A520FOJV9CSD1/A520FXXU9CSD4/A520FXXS9CSD2 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J915M7ZN Imei: Unique Number: CBJ00AFDAFA8074 Connections: AT,MTP Battery Status: 4.28V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.3:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [06.09.19 00:57:38] WorkID: 62246405 tnx Chimera team |
The Following 3 Users Say Thank You to abbasdvd For This Useful Post: |
06-09-2019, 05:37 | #2 (permalink) |
Major Poster Join Date: Sep 2018
Member: 2863973 Status: Offline Thanks Meter: 6 | i am success also but ng no network emergency call only [QUOTE=abbasdvd;13686605]Chimera Mobile Phone Utility version: 21.34.1308 @ 2019-06-09 Printing phone history Patch Certificate 6/8/2019 8:22:47 PM Patch Certificate 6/8/2019 8:20:47 PM Repair IMEI 6/8/2019 8:18:12 PM Patch Certificate 5/28/2019 3:57:34 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: THR Country Code: IRAN Timezone: Asia/Tehran Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Apr 9 16:08:23 KST 2019 PDA Version: A520FXXS9CSD2 [april 2019, rev2] Phone Version: A520FXXU9CSD4 [april 2019, rev4] CSC Version: A520FOJV9CSD1 [april 2019, rev1] Product Code: THR HIDSw Version: A520FXXS9CSD2/A520FOJV9CSD1/A520FXXU9CSD4/A520FXXS9CSD2 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J915M7ZN Imei: Unique Number: CBJ00AFDAFA8074 Connections: AT,MTP Battery Status: 4.28V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.3:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [06.09.19 00:57:38] WorkID: 62246405 tnx Chimera team[/QUOTEi am success also but ng no network emergency call only need help please |
The Following User Says Thank You to Raazgsm1 For This Useful Post: |
06-09-2019, 13:05 | #3 (permalink) | |
Member: 2499218 Status: Offline Thanks Meter: 44 | https://drive.google.com/file/d/15GrwY0pf6iDysZToVEy2h0FA0FWQQnuN/view?usp=sharing [QUOTE=Raazgsm1;13686735] Quote:
flash :https://drive.google.com/file/d/15Gr...ew?usp=sharing | |
