Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member ![]() ![]() Join Date: May 2015
Member: 2393189 Status: Offline Thanks Meter: 5 | A125F U2 patch done but baseband unknown Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A125F Carrier ID: XME Sales Code: SER Country Code: Russia Timezone: Europe/Istanbul Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Thu Feb 10 12:11:03 +07 2022 PDA Version: A125FXXU2BVB3 [february 2022, rev3] Phone Version: A125FXXU2BVA5 [january 2022, rev5] CSC Version: A125FOXM2BVB3 [february 2022, rev3] Product Code: SER HIDSw Version: A125FXXU2BVB3/A125FOXM2BVB3/A125FXXU2BVA5/A125FXXU2BVB3 Board Platform: MT6765 Modem Platform: MT6765 Serial Number: RR8R800J2LH Imei: 35xxxxx Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-02-01 Em Did: 48DB1F45EDB4 Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.18.22 17:20:00] WorkID: 180638702 Repair and patch done but 1-2 minute after baseband unknown Backup nvdata,nvram,efs writing after patch done after baseband unknown flash, wipe nv all methods have been try help me plss |
![]() | #2 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2007
Member: 516790 Status: Offline Thanks Meter: 19 | i have the same problem A125F U2 patch done but baseband unknown Chimera Mobile Phone Utility version: 32.05.1009 @ 2022-05-18 Printing phone history Restore / Store backup 18.05.2022 17:22 Restore / Store backup 18.05.2022 17:18 SW Change 18.05.2022 10:12 Patch Certificate 18.05.2022 10:01 Patch Certificate 18.05.2022 10:00 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A125F Carrier ID: XME Sales Code: SER Country Code: Russia Timezone: Europe/Istanbul Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Thu Feb 10 12:11:03 +07 2022 PDA Version: A125FXXU2BVB3 [february 2022, rev3] Phone Version: A125FXXU2BVA5 [january 2022, rev5] CSC Version: A125FOXM2BVB3 [february 2022, rev3] Product Code: SER HIDSw Version: A125FXXU2BVB3/A125FOXM2BVB3/A125FXXU2BVA5/A125FXXU2BVB3 Board Platform: MT6765 Modem Platform: MT6765 Serial Number: RR8R800J2LH Imei: 355963050041045 Connections: AT,MTP Network Type: GSM SIM Status: UNKNOWN,UNKNOWN Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-02-01 Em Did: 48DB1F45EDB4 Preparing... Previously installed patchcert detected. Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.18.22 20:26:51] WorkID: 180670387 |
![]() | #3 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012
Member: 1787203 Status: Offline Thanks Meter: 22,171 | reply Dear Cangsm, Thank you for the report. We will send the Work to the developers. Hopefully, soon we can find a solution for it. However, you can try to reflash the device with a stock Firmware, which contains a different modem version. Best regards Sab Chimera team Quote:
