09-20-2021, 17:34 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | A20e a202f u3 repair chimera Printing phone history Reboot 20.09.2021 09:43 Reboot 20.09.2021 09:21 Reboot 20.09.2021 09:11 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A202F Carrier ID: ATO Sales Code: ATO Country Code: Austria Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Jan 2 12:47:34 KST 2020 PDA Version: A202FXXU3ASL4 [december 2019, rev4] Phone Version: A202FXXU3ASL3 [december 2019, rev3] CSC Version: A202FOXM3ASL3 [december 2019, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58MA4JGS0H Imei: 3520471155 Imei2: 352048115 Battery Status: 4.33V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-01-01 Em Did: 61B777532466 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 3520471155 Repaired imei: 35826305 Current imei2: 3520481155 Repaired imei2: 35826308075 Successfully finished. Finished at local time: [09.20.21 19:32:20] WorkID: 151203430 Chimera Mobile Phone Utility version: 29.67.2050 @ 2021-09-20 Printing phone history Repair IMEI 20.09.2021 16:30 Reboot 20.09.2021 09:43 Reboot 20.09.2021 09:21 Reboot 20.09.2021 09:11 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A202F Carrier ID: ATO Sales Code: ATO Country Code: Austria Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Jan 2 12:47:34 KST 2020 PDA Version: A202FXXU3ASL4 [december 2019, rev4] Phone Version: A202FXXU3ASL3 [december 2019, rev3] CSC Version: A202FOXM3ASL3 [december 2019, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58MA4JGS0H Imei: 3582630805 Imei2: 358263085 Battery Status: 4.27V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-01-01 Em Did: 61B777532466 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [09.20.21 19:33:35] WorkID: 151203823 |
The Following User Says Thank You to mathew_di For This Useful Post: |
09-21-2021, 09:51 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear User, Thank you for both works! Excellent jobs from you! Best regards Sab Chimera Team Quote:
